Author Topic: Coolant system Sealants  (Read 4555 times)
Henry Cloutier
« on: January 20, 2022, 12:29:26 PM »
Hello to all!
Has anyone had experience using sealant tabs in cooling systems? The radiator in the Z is leaking and there is only one radiator shop here in town and their best guess to repair (if possible) is about the same as replacing with a new unit from Camaro Cantral. While it would be nice to have the original stay in the car I'm not sure I want to give the shop that kind of money for a maybe good radiator. I have heard of these different sealants with mostly positive reviews and would like to know what you all think.
best regards,
Hank
camaronut
Re: Coolant system Sealants
« Reply #1 on: January 20, 2022, 02:31:35 PM »
Don’t use those sealants.  Fix or replace the radiator.  Those sealants do more harm than good.
Z10Mike
« Reply #2 on: January 20, 2022, 09:49:48 PM »
Some of those sealants can work their "magic" on the heater core as well.  As in completely blocked.
Henry Cloutier
« Reply #3 on: January 20, 2022, 11:16:31 PM »
Thanks for the replies! I've never been a big fan of additives so your opinions pretty much align with mine. New radiator it is then!
Best regards,
Hank
« Reply #4 on: January 29, 2022, 12:12:38 AM »
I'd repair. I like original parts vs repro.
And realize that all the OEM's put a little pill of stopleak (ginger root) in every cooling system. Helps enormously with warranty claims.
« Reply #5 on: January 29, 2022, 02:39:59 AM »
Yep used the GM tablets many times and work great for a tiny leak.  But as said. Pull the radiator and have it repaired.
Henry Cloutier
« Reply #6 on: January 29, 2022, 12:08:34 PM »
I'll research the repair option further. Perhaps the shop was confused about repair pricing versus replacement cost.
Thanks you all!
« Reply #7 on: January 29, 2022, 01:54:53 PM »
I have used Glen-Ray Radiator to recore radiators and heater cores. Sometimes he has Harrison cores in stock. Had two local shops butcher a job. Big difference in repairing a radiator and restoring one. I found him by using that google thing. T^ook a couple seconds. I've posted this info on this site before. We had a radiator shop attached to our bodyshop so I know the difference between quality work and garbage.
MO
« Reply #8 on: January 29, 2022, 08:55:05 PM »
How original is your car? If it's mostly original, re core the radiator and put it back in. If your car is modified or originality is not important, buy a new radiator and store the original for later use. Additives can be problematic, but I never had issues the couple times I needed an emergency fix; and they did the job.
Henry Cloutier
« Reply #9 on: January 30, 2022, 12:19:10 PM »
As best I can tell the car is still mostly original, but I don't have any prior maintenance info/log. I would like to keep it as close as I can within reason of course. I'm heading to the radiator shop here on Monday for a face to face rather than the previous contact which was by phone. Given the shipping fiasco happening these days I'd rather stay local if at all possible. I have seen the Glen-Ray name in prior posts; do they have a standard turn time?
Hank
« Reply #10 on: April 15, 2022, 03:02:34 AM »
I have had a number of radiators done at my local shop and have had people send in radiators to them as well. Last was a 69 COPO chevelle rad and a 71 vette big block Air con rad. new cores using the original tanks and rails $600 on the chevelle rad they hammered out tank dents and silver soldered a few pin holes in the drivers side tank for the $600.
Augusta Road Radiator
Phone: (864) 277-2928
Address: 3488 Augusta Rd, Greenville, SC 29605
Henry Cloutier
« Reply #11 on: April 15, 2022, 10:50:24 AM »
Thanks for the info! The original is still out of the car and needs more repair than the local shop here can perform.
Best regards,
Hank
David K
  • Dr. Longblock
« Reply #12 on: April 16, 2022, 03:07:05 AM »
Replace it, have a competent shop repair it and store it in the box the replacement came in.
Henry Cloutier
« Reply #13 on: April 16, 2022, 10:32:20 AM »
Makes sense to me.
Thanks!
Hank
« Reply #14 on: April 19, 2022, 07:10:41 PM »
But that undermines the originality of the car. It doesn't make the car more original if the original parts are somewhere in a box.
And you then get to store the second radiator.
Just get the rad repaired.....
