Author Topic: 1969 Rear brake soft line for 12 bolt  (Read 1695 times)
Driveway_finds
« on: September 19, 2021, 05:13:57 PM »
Does anybody have pictures of an original brake line on a car? Does it mount with the brake line as part of the rubber hose, or separate? Is the soft line supposed to screw into a brass block? Thanks!
1969 RSSS L78
1970 RS L78 clone
1970 C10 LS swap
Check out driveway_finds on Instagram!
Re: 1969 Rear brake soft line for 12 bolt
« Reply #1 on: September 19, 2021, 07:58:17 PM »
Block isn't used when the hose has the distribution included...
The blocks were used on 67's possibly 68. They use a hose which has a male fitting - and screws into the block.
69 uses the hose with the distribution fitting attached to the hose.
This is the one on my old 70 Z28 but the same applies for 1969.
Driveway_finds
« Reply #2 on: September 19, 2021, 08:00:40 PM »
Great, thank you!
1969 RSSS L78
1970 RS L78 clone
1970 C10 LS swap
« Reply #3 on: September 19, 2021, 08:06:14 PM »
You will also need to get the correct bracket, the one in your pic is for the brass block.
That type may be the original type for your C10 pickup - everything newer than 69 car wise I believe had the block attached, 67 and earlier have the brass block with the rubber line configured female - car end - male axle end.
Driveway_finds
« Reply #4 on: September 19, 2021, 11:09:04 PM »
Perfect, I’ll save the brass block and bracket for my 67 Big Block Pacecar. Thanks!
1969 RSSS L78
1970 RS L78 clone
1970 C10 LS swap
