Author Topic: Radiator Overflow Hose - Length  (Read 3744 times)
Edgemontvillage
« on: August 26, 2021, 04:54:50 PM »
Looking for the correct length of the thin wall radiator overflow hose. The AIM provides no details and I assume the hose length was the same for all Gen 1's however if not I'm looking for a 69 Z. Thanks.
« Last Edit: August 26, 2021, 05:23:26 PM by Edgemontvillage »
BillG
Re: Radiator Overflow Hose - Length
« Reply #1 on: August 26, 2021, 07:33:57 PM »
Lloyd; mine is 18".  O3B L48 Pace car.  I believe it to be original to the car.
Bill Garrett
« Reply #2 on: August 26, 2021, 08:11:06 PM »
  The original still on my '67 04B LOS w/L35 auto-radiator measures exactly at 18 1/2" when using a tape measure to follow the hoses contour. I tried to pry it off the radiator nipple but it is stuck on and I didn't want to risk tearing
 the rubber.
Edgemontvillage
« Reply #3 on: August 26, 2021, 11:36:51 PM »
Thanks Mike & Bill, much appreciated!
« Reply #4 on: August 27, 2021, 03:51:56 AM »
17" on the curve. Lost a bit but original ribs, thin wall, dia, etc.
Pic
Edgemontvillage
« Reply #5 on: August 30, 2021, 04:27:17 AM »
Cut to 18" length
[/url]
« Reply #6 on: August 30, 2021, 09:21:15 AM »
That looks so good.
Is the fan shroud NOS or did you work some Lloyd magic on it?
 radiator tag - thumbs up.
Edgemontvillage
« Reply #7 on: August 30, 2021, 02:10:43 PM »
Thanks James, the radiator shroud is NOS dating back to the early '90s.
« Reply #8 on: August 30, 2021, 03:09:48 PM »
I wonder what prompted GM in '69 to add a part to hold the hose end instead of using the clip I see in the photo that is already part of the radiator assembly like in '67 (and 68?). Granted the part probably costs cents to produce but you know how the bean counters think.
Gars68Tux
« Reply #9 on: August 30, 2021, 10:07:18 PM »
 ...and to dump overflow on the rad hose ? Would make a person wonder if the lower (rad) hose was leaking... :-\
Garth
68 RS L30 AA 749 Fred Gibb Chevrolet
« Reply #10 on: August 31, 2021, 02:50:57 PM »
My as found LOS 1968 "UH"
hugrz28
« Reply #11 on: September 23, 2021, 04:57:24 PM »
Does anyone know who makes an accurate, quality reproduction?
Edgemontvillage
« Reply #12 on: October 07, 2021, 08:09:47 PM »
I sourced mine from Inline Tube / Motorcity Musclecar Restoration Parts. Theirs is the correct thin wall design (with 3 ribs). Its sold in 25" length.
hugrz28
« Reply #13 on: October 08, 2021, 03:49:03 PM »
Thank you for responding. What I meant to say in my post is the clip that attaches to the radiator tank and holds the hose. That is the piece I was wondering about and if a reproduction is made and where to buy it from.
