Author Topic: 124379L519293 - Missing Original Cowl Tag - What is it worth  (Read 2648 times)
69RALLYSPORTZ28
Is $25k a fair price when missing the original cowl tag and also missing the original engine, transmission and rear end?
Would spending another $10k - $15k get a 69 worth so much more if I had to sell it in 5 to 10 years
https://www.ebay.com/itm/133776819084
« Last Edit: June 01, 2021, 10:36:42 PM by 69RALLYSPORTZ28 »
Re: 124379L519293 - Missing Original Cowl Tag - What is it worth
« Reply #1 on: June 01, 2021, 09:14:05 PM »
yes iff going the resto-mod route. Numbers mean very little in that market. For a stock Camaro, it is going to make for a harder future sell. I personally wouldn't dump more money into it, if it was missing the trim tag.
Fred Mertz
« Reply #2 on: June 08, 2021, 12:42:50 AM »
Interesting.... My "69 is 124379L519275  01D
 Possibly same day production?
jj69z28
« Reply #3 on: August 16, 2021, 02:38:12 AM »
close to mine as well 519384
Rally Green 69 Z/28
crossboss
  • ^ New engine project
« Reply #4 on: August 16, 2021, 06:11:33 PM »
My worthless two cents...
A 'trim tag' or 'buck tag' is simply a plate attached to the body denoting its options, colors and where it was built. It is NOT a VIN. Since its missing, and what the others have mentioned, for a 'correct' car it will be a slight loss in value. IF you intend to build a modified car, its not really needed anyways. However, ANY potential car worth owning should have one in place. I'm not qualified to comment on a Camaro's reproduction buck tag, or where you can have one made. I do know that in the Ford world Kevin Marti will sell you one for your car...IF you can prove you own it.
1968 Olds 442 W-30
x55cam
« Reply #5 on: August 20, 2021, 02:06:33 PM »
Well, maybe on a 68 since the trim tag info had limited information about the options it came with - unfortunately Chevy in their infinite wisdom decided to get lazy on this for whatever reason. But 67's and for the most part 69's they are important. Especially a car as rare as a 67 Z28. Without that tag , assuming no paper work or ownership documents, it's a huge $$ difference.  And yes, it goes without saying that tags can be forged - but it helps to have the knowledge to check and verify.
Be careful about reading  health books. Some fine day you'll die of a misprint. - Markus Herz
crossboss
« Reply #6 on: August 20, 2021, 06:34:25 PM »
Absolutely! ANY potential car with value/rarity missing buck tags, VINS, and proper paperwork is a major hit on value. As my wealthy car collector friends always say: "No documentation, NO premium"
1968 Olds 442 W-30
