Author Topic: V0217DZ with two sideways letters M for 124379N803507  (Read 6145 times)
69RALLYSPORTZ28
« on: April 22, 2021, 03:23:01 AM »
Does anyone else have an original DZ 302 block with two sideways letters M at the beginning and the end of the plant, date and engine suffix stamping?
ric1969
Re: V0217DZ with two sideways letters M for 124379N803507
« Reply #1 on: April 22, 2021, 12:14:20 PM »
 Saw that on ebay i didn't like one bit of it.
« Reply #2 on: April 22, 2021, 01:17:01 PM »
ONLY $7500 ...  so you could take a chance!~    LOL
jdv69z
  • 69 RS Z/28 52E
« Reply #3 on: April 22, 2021, 01:25:11 PM »
I thought VIN #'s ended in 9N711xxx range.  :P
Jimmy V.
« Reply #4 on: April 22, 2021, 01:47:07 PM »
Last 1969 Camaro produced was N711922.
« Reply #5 on: April 22, 2021, 03:23:09 PM »
I have a different picture and it looks like 9N603507, but it's hard to see the 6.
Pad looks ok.
ric1969
« Reply #7 on: April 23, 2021, 01:57:03 PM »
 the only thing look's good is the date casting numbers
« Reply #8 on: April 23, 2021, 02:11:04 PM »
Pad looks ok.
Kurt, that explains the incorrect VIN posted, but what was your opinion of the pre/post 'sideways M'?   Have you ever seen anything like that before? (I haven't).   I also thought the 'std' characters in the app stamp looked OK, but since the broach marks were not captured in the photo, I would not say that the stamp was 'original'...   Would you?  and if so, how do you explain the pre/post characters stamped??
« Reply #9 on: April 24, 2021, 05:29:08 AM »
Someone / machine shop added.
ric1969
« Reply #10 on: April 24, 2021, 01:54:23 PM »
  been decked and re stamp nothing match
« Reply #11 on: April 25, 2021, 03:55:18 AM »
The engine pad stamp appears original to me, font and characters look good. The "M" was probably added by an owner during a trip to the machine shop, I always stamped my initials in an inconspicuous part of the casting in case it got "destroyed" or "lost" during the machining process (I wouldn't have done this obvious a stamp location !) Maybe that sounds paranoid, and I guess it was, as I never had one turn up missing (but I've heard horror stories over the years, too). If the VIN stamp above the filter is a 6 rather than an 8 as it seems from a casual glance, that could be pretty close to the range. My Z11's 3/17 built block carries a 620 VIN -
« Reply #12 on: April 25, 2021, 02:57:29 PM »
The V0217DZ stamping is original.
ric1969
« Reply #13 on: April 26, 2021, 05:59:20 AM »
 Reading Steve's comment , I've changed my mind does look good just can't see those broach marks.
« Reply #14 on: April 26, 2021, 12:29:41 PM »
There ARE people who can perfectly match the factory stampings, but replicating the factory broach marks after a machining is not as easy!~
I'm like Ric..  I want to see factory broach marks before verifying authenticity!
And like Steve, I've also added my initials to a block before going to the machine shop, but never would I add them to the factory pad area, and can't understand anyone adding those M's to a factory stamping!
