Author Topic: Storage during off season ?  (Read 16672 times)
WaltZ
Re: Storage during off season ?
« Reply #15 on: November 23, 2020, 02:58:19 PM »
Best way for storage
A:up on stands with loose suspension with wheels off floor
   and if not WHY?
B:or drive in and let it sit normally.
Thanks in advance
W
WaltZ
« Reply #16 on: November 23, 2020, 03:02:40 PM »
that's how I store it, on stands and loose suspension, makes sense to me.
like to know why some say to leave sitting and loaded.
Thanks again
« Reply #17 on: November 25, 2020, 12:09:32 AM »
Make sure and start the car every week or two, and warm it to operating temp to keep the fluids circulated - acids are fond of forming in oil over the winter, plus you need the rust preventative in the coolant to circulate occasionally.
I would NOT recommend starting a car like that. The acids form when the engine is running. Sitting, nothing happens. You won't get the engine and the exhaust up to temp to burn off the acids, so you are just adding to them.
The coolant doesn't need to circulate, it's touching everything it needs to.
Do museums start up their cars? No......
« Reply #18 on: November 25, 2020, 12:29:38 AM »
We have owned an '89 Camaro RS convert for 27 years. Same procedure every year: fill the tank, wood under the tires, battery tender, do not set the parking brake. Not started for at least 6 months, fires right up come spring.
« Reply #19 on: November 25, 2020, 04:34:48 AM »
Fresh oil change prior to storage would be the only thing if storing for any length of time, that way there is not fouled oil sitting in the bearings and crank case.
We drive our cars at least once a month during the winters if not more, so it's not very frequently that they are sitting for more than a few weeks.
Kelley W King
« Reply #20 on: November 25, 2020, 12:58:36 PM »
I am a believer that some kind of humidity or climate control is the best thing you can do for indoor storage. My first garage was wood frame with no insulation and the windows would sweat at times summer and winter. My vette which except the 6 years prior to my ownership never stayed outside still developed frame rust from the inside. I am in NC by the way.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
jcabuilder
« Reply #21 on: November 26, 2020, 01:19:40 AM »
I just placed my 69 Camaro in storage and spread mothballs on the floor.  Today, I saw someone on YouTube doing an experiment with mothballs ato determine if it actually repelled mice. Nope, doesn't work to my dismay, nor does Irish Spring soap.  Mint, peppermint or peppermint tea bags placed in the 4 corners of the garage worked the best. Check it out on YouTube. I have my wife checking to see if we have any of that stuff right now.
1969 Z28 X33 Tuxedo Black
2007 BMW Z4 Sapphire Black Metallic
2016 Ford F150 King Ranch Shadow Black
« Reply #22 on: November 26, 2020, 03:20:06 AM »
Mothballs are for moths... :) ...   I also have heard that when dropped into gasoline will increase the octane....  :)
68Tiger
« Reply #23 on: November 26, 2020, 12:20:29 PM »
My routine for Michigan winters. I have an un-heated insulated and finished garage. Same routine for 8 years with no issues. It works for me.
Around the first week in November: Starting with a thoroughly cleaned and detailed car. I fill the tank with Premium gas, add Stabil Long term Storage stabilizer (use Stabli 360 for everyday use), change oil, pull the battery and put on my work bench, hook battery to a Noco battery maintainer, over-inflate tires 5#, roll windows down 6 to 8", place OmniDry desiccant packs inside cab & in trunk, cover car with a good quality car cover, place car in a CARJACKET CarBag with additional OmniDry desiccant packs placed in various areas underneath the car, place anti fatigue rubber matting under all tires and zip up bag to seal in. Remove car in April/May. Note, you will have a slight fuel smell when first unzipping the bag however no worries it will quickly dissipate and there will be no lasting side effects.
https://www.carbag.com/carjacket/
« Last Edit: November 26, 2020, 01:09:55 PM by 68Tiger »
69 Camaro RS
327ci Automatic
12 bolt posi. / 3.55
« Reply #24 on: November 26, 2020, 03:58:40 PM »
I have tried about everything. Fresh Cab seems to work best for keeping mice away. But nothing is fool proof.
« Reply #25 on: November 26, 2020, 04:38:39 PM »
I tend to think more in terms or keeping oil films intact on bearings and internal rotating assemblies. You're correct about coolant, but if there are any internal coolant passages not covered, it's gonna rust/oxidize. Hoses can deteriorate. Hydraulic lifters can bleed down, valve springs can take a "set" when compressed over long periods of time. True, you need to get the engine up to operating temps to drive off the moisture formed during the combustion process, which doesn't help anything if it builds up in the engine or exhaust systems. If you can't do that due to the locale and long term bad weather - you're correct. Let it sit.
Some museums and collectors will store/display vehicles "dry", prep them only when they need to be driven. I was surprised to see that during one prominent collection auction in TN a few years back - the auction magazine stated that fact well before the auction that all of the vehicles sold would need complete servicing before starting or use due to no coolant or fluids installed. Bummed out the people that wanted to hear things run - but didn't affect the auction proceeds.
Just my opinions - works for me.
GMAD_Van Nuys
« Reply #26 on: November 26, 2020, 05:07:49 PM »
I once didn't drive a car which has hydraulic lifters for about 6 months and when I started it, the lifters had bled-down and for a few seconds, it was louder than the solid lifters in my 1970 BOSS 302!
68L30
« Reply #27 on: November 27, 2020, 02:37:50 PM »
Been storing 35 + years this way, minus battery, Stabil added, visors down, mats out, Irish Spring in,  Damp Rid, on wood, car covered, and into the bag it goes. Comes out perfect every year.
« Reply #28 on: November 27, 2020, 07:02:43 PM »
My brother's corvette was stored for 30 years inside a car bag with desiccant bags... the frame is beautiful on his car.
67L78
« Reply #29 on: November 28, 2020, 02:56:12 PM »
I know a guy that had a 67 L78 Chevelle and he would start it once a week during winter storage and let it run a few minutes. Then one time he hit the key switch to start it and “Boom!!”. Internal engine explosion. It puffed out the valve cover, blew valve cover “, intake , carb, distributor gasket out. Even the pan gasket. He was lucky it didn’t catch fire and burn everything.
I think the Holley carb some how let gas seep down into the engine or fuel pump failure will pump gas into the bottom end. Who knows but it happened.
I never start my car during winter storage.
1967 4K
