Author Topic: 9428047 rivet  (Read 3669 times)
x66 714
9428047 rivet
« on: November 12, 2020, 07:34:53 PM »
Does anybody have the specs on a 9428047? Is it a pop rivet or something else? In the 1969 AIM, it calls for 2 to hold the heater control valve & 2 to hold a bracket to the fender well that holds the main a/c hose. Ref; C60 D6.5 & C60 D5. The currant part is a pop rivet.Thank you, Joe
Re: 9428047 rivet
« Reply #1 on: November 12, 2020, 07:52:48 PM »
https://www.gmpartsgiant.com/parts/gm-rivet-dom-9428047.html
Description: blind rivet, dome head-
FWIW - blind rivets are typically pop rivets.
Re: 9428047 rivet
« Reply #2 on: November 12, 2020, 10:31:17 PM »
Search
Semi Tubular Rivets or Hollow-end rivets
Choose; Head style,  Material, Diameter and (LG) For Maximum Material Thickness also order a Set tool (Clinch striker) and practice a few strikes and go for it.
Other area used in F Body; Heater Duct Flappers, Ash tray bracket slider, Door channel seal blow out retainers, 68 Grill side mounts etc,,,,,,,
I do not know of ANY pop rivets used in a First Gen
x66 714
Re: 9428047 rivet
« Reply #3 on: November 13, 2020, 01:31:53 AM »
Thanks James & Jim. I guess I need to find an 1969 a/c car that hasn't been taken apart...Joe
Re: 9428047 rivet
« Reply #4 on: November 13, 2020, 01:39:46 PM »
Nor do I, however I do not believe I have ever seen a blind rivet which was set by access to the back.
x66 714
Re: 9428047 rivet
« Reply #5 on: November 13, 2020, 01:56:02 PM »
I got an e-mail over night from someone that has an original a/c car that is untouched. I'll see what he sends me & then I'll ask him if I can share...Joe
JKZ27
Re: 9428047 rivet
« Reply #6 on: November 13, 2020, 08:40:47 PM »
Ill look at mine also.
John
68 RS Ash/Ivy Gold 327EFI M20
Dusk Blue Z
Re: 9428047 rivet
« Reply #7 on: November 14, 2020, 01:57:16 PM »
[/quote]
VIN Tag
1969 Z/28 Legends Certified
1969 Z-10 Under Construction
Re: 9428047 rivet
« Reply #8 on: November 14, 2020, 03:44:06 PM »
Good Call mike,
Implied but I failed to state:
"I do not know of ANY round head pop rivets used in a First Gen"
Well, Crud   I wonder if somewhere else one round pop rivet could be lurking I have forgotten, Interior,,,,inside some sub assy,,,,,,
I am not a Air conditioning guy so It will be interesting to see some photos of AC usage of ???? RIVETS
x66 714
Re: 9428047 rivet
« Reply #9 on: November 14, 2020, 09:59:29 PM »
Warren (work in progress) sent me this picture of his unrestored 69 with a/c...Joe
JKZ27
Re: 9428047 rivet
« Reply #10 on: November 15, 2020, 01:09:39 AM »
Here is mine.
John
x66 714
Re: 9428047 rivet
« Reply #11 on: November 15, 2020, 01:40:52 AM »
Thank you John...Joe
