Author Topic: 1969 rear license plate bracket GM 3913608  (Read 5847 times)
Danzo
« on: August 08, 2020, 05:42:51 PM »
Does anyone have a picture (front and rear) of an original? Was there more than 1 supplier?
Thanks, Doc.
Re: 1969 rear license plate bracket GM 3913608
« Reply #1 on: August 08, 2020, 06:15:53 PM »
Top is OE '69. Bottom is GMPD substitute up to the '90s.
« Reply #2 on: August 08, 2020, 10:45:51 PM »
Try these. I apologize for the scroungy appearance - off my X77, disassembled in 1980 or so. Front, back and part number stamp. The original bolts are on the bracket, marked with a single "P".
Danzo
« Reply #3 on: August 08, 2020, 11:46:48 PM »
William and Steve, thank you!
Doc
ZLP955
« Reply #4 on: August 09, 2020, 12:25:54 AM »
I think at least 2 suppliers is likely, many have AAc stamped on them but I have also seen them stamped with a triangle symbol containing a letter (including the one on my LA car).
Tim in Australia.
169INDY
« Reply #5 on: August 09, 2020, 12:28:45 AM »
Were they basically 60% or Full gloss, dip painted, runs and all as an assembly,,,,,
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
WorkinProgress
« Reply #6 on: August 09, 2020, 07:31:46 AM »
There is different font sizes that you have to be aware of.
                                                - Warren
Danzo
« Reply #7 on: August 09, 2020, 12:32:58 PM »
More example pictures needed?
Doc
x66 714
« Reply #8 on: August 09, 2020, 02:38:07 PM »
Mine is exactly like Steve's (z28 z11). Norwood built 8/28/1969....Joe
« Reply #9 on: August 09, 2020, 11:05:55 PM »
I looked at the other 2 - the 03D Pace Car is like the 01C X77 - stamped GM and part number. The 12A '68 built L78 is different - lot of surface rust, appears either to be an AAc or triangle marking, I'll have to give it a bath in Evaporust or the old electrolysis routine to be sure, but it is different. All were built in Norwood, might be a vendor change somewhere in the first part of the year at Norwood. Need more examples to find a pattern -
ZLP955
« Reply #10 on: August 10, 2020, 08:03:04 AM »
Picture of the triangle stamp on my car's bracket in this thread: http://www.camaros.org/forum/index.php?topic=10725.msg148772#msg148772
Tim in Australia.
fiveforty
« Reply #11 on: August 10, 2020, 05:49:20 PM »
The production line fonts were a little different than the ones produced OTC
Edgemontvillage
« Reply #12 on: August 11, 2020, 04:20:37 AM »
I'd say you're right at 60% gloss - definitely more gloss than many of the supplier parts. Here are photos of my original bracket (partially stripped for paint) from my 2B Norwood RS/Z:
ZLP955
« Reply #13 on: August 11, 2020, 07:14:45 AM »
Great to see another 'P' in a triangle, Lloyd - and clearly not just an LA plant supplier then!
Tim in Australia.
« Reply #14 on: August 12, 2020, 12:43:05 AM »
Tim and Lloyd,
Triangle/P on the same bracket with the GM part number stamp as well ? What area does it appear in ?
x66 714
« Reply #15 on: August 12, 2020, 01:33:18 AM »
Steve. They're on opposite sides from each other....Joe
« Reply #16 on: August 12, 2020, 02:06:18 AM »
Man, I gotta clean these up a bit. I thought I looked them over pretty carefully, but old eyes can fool you. Sorry I missed the obvious !
x66 714
« Reply #17 on: August 12, 2020, 11:20:39 AM »
I know about old eyes. I have to get my readers out all the time :)
...Joe
ZLP955
« Reply #18 on: August 12, 2020, 11:56:11 AM »
Tim and Lloyd,
Yes, mine has both GM part number and 'P' stamp, and as Joe said, on opposite sides of the bracket (also just like Lloyd's). You can make out the 'P' stamp in Lloyd's first picture, bottom right corner, around the 3-3/8" mark on the ruler on top.
Tim in Australia.
Edgemontvillage
« Reply #19 on: August 12, 2020, 04:57:29 PM »
« Reply #20 on: August 12, 2020, 09:27:34 PM »
...Joe
Same here. I resisted as long as I could, cringe every time I have to step up the magnification on my El Cheapo OTC readers. I'm gonna wear them in a minute to look for the triangles on the two in the garage -
« Reply #21 on: August 12, 2020, 09:30:39 PM »
Lloyd - thanks, I know where to concentrate my excavating. What process are you using to prepare this - vapor blast ? Really superior -
Edgemontvillage
« Reply #22 on: August 14, 2020, 02:19:53 PM »
[/quote]
Steve, what you see in the photo is the result of dry media blasting only using fine glass bead at 80PSI. The fine bead produces a near-polished surface which sets up well for paint. Following media blasting I'll sand the piece with 400 grit paper to "knock down" the surface then mask off the GM part number and manufacturers stamp before a thorough wipe down with prep sol followed by a light coat of epoxy primer.
Edgemontvillage
« Reply #23 on: August 31, 2020, 03:52:28 PM »
Here's the finished product. I had previously restored an NOS bracket for my project only to discover the part number had been superseded (so that won't do) and the finish I applied was 30% gloss and I now believe it should be in the 60-80% range (or full gloss by 1969 standards).
