Author Topic: 1969 rear license plate bracket GM 3913608  (Read 5854 times)
Danzo
« on: August 08, 2020, 05:42:51 PM »
Does anyone have a picture (front and rear) of an original? Was there more than 1 supplier?
Thanks, Doc.
Re: 1969 rear license plate bracket GM 3913608
« Reply #1 on: August 08, 2020, 06:15:53 PM »
Top is OE '69. Bottom is GMPD substitute up to the '90s.
« Reply #2 on: August 08, 2020, 10:45:51 PM »
Try these. I apologize for the scroungy appearance - off my X77, disassembled in 1980 or so. Front, back and part number stamp. The original bolts are on the bracket, marked with a single "P".
Danzo
« Reply #3 on: August 08, 2020, 11:46:48 PM »
William and Steve, thank you!
Doc
« Reply #4 on: August 09, 2020, 12:25:54 AM »
I think at least 2 suppliers is likely, many have AAc stamped on them but I have also seen them stamped with a triangle symbol containing a letter (including the one on my LA car).
« Reply #5 on: August 09, 2020, 12:28:45 AM »
Were they basically 60% or Full gloss, dip painted, runs and all as an assembly,,,,,
WorkinProgress
« Reply #6 on: August 09, 2020, 07:31:46 AM »
There is different font sizes that you have to be aware of.
                                                - Warren
Danzo
« Reply #7 on: August 09, 2020, 12:32:58 PM »
More example pictures needed?
Doc
x66 714
« Reply #8 on: August 09, 2020, 02:38:07 PM »
Mine is exactly like Steve's (z28 z11). Norwood built 8/28/1969....Joe
« Reply #9 on: August 09, 2020, 11:05:55 PM »
I looked at the other 2 - the 03D Pace Car is like the 01C X77 - stamped GM and part number. The 12A '68 built L78 is different - lot of surface rust, appears either to be an AAc or triangle marking, I'll have to give it a bath in Evaporust or the old electrolysis routine to be sure, but it is different. All were built in Norwood, might be a vendor change somewhere in the first part of the year at Norwood. Need more examples to find a pattern -
« Reply #10 on: August 10, 2020, 08:03:04 AM »
Picture of the triangle stamp on my car's bracket in this thread: http://www.camaros.org/forum/index.php?topic=10725.msg148772#msg148772
fiveforty
« Reply #11 on: August 10, 2020, 05:49:20 PM »
The production line fonts were a little different than the ones produced OTC
Edgemontvillage
« Reply #12 on: August 11, 2020, 04:20:37 AM »
I'd say you're right at 60% gloss - definitely more gloss than many of the supplier parts. Here are photos of my original bracket (partially stripped for paint) from my 2B Norwood RS/Z:
« Reply #13 on: August 11, 2020, 07:14:45 AM »
Great to see another 'P' in a triangle, Lloyd - and clearly not just an LA plant supplier then!
« Reply #14 on: August 12, 2020, 12:43:05 AM »
Tim and Lloyd,
Triangle/P on the same bracket with the GM part number stamp as well ? What area does it appear in ?
