Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
Aftermarket core support
« previous
next »
Print
Pages: [
1
Author
Topic: Aftermarket core support (Read 1998 times)
BillOhio
Hero Member
on:
June 21, 2020, 07:00:17 PM »
Hi Guys.
Anyone used an aftermarket core support that fit right? I am working on a 68 and have a replacement but it is like 2 pounds lighter than a stock one and you can grab the top and flex it with your hand. The stock one I ran across is pretty swelled up around the bushing holes to want to fix it
Tweet
Logged
1968 RS 327 4 speed
Hero Member
owner since 4-Apr-1976
Re: Aftermarket core support
Reply #1 on:
June 22, 2020, 04:06:09 AM »
A few years ago, I looked at several mfg, and the AMD was by far the most correct core support, but even that one wasn't a perfect reproduction...
Logged
72 El Camino, '55-'56-'57 Nomads, '55-'57 B/A Sedan
KevinW
Hero Member
Reply #2 on:
June 22, 2020, 11:13:16 AM »
Use the repro brackets (bushing holes) to fix the original one!
Logged
BillOhio
Hero Member
Reply #3 on:
June 22, 2020, 11:44:16 AM »
The original I have is swelled up pretty bad where the different layers come together. Too bad they didnt make a drain in them where this happens.
Not much on the car will be stock but wanted the front to fit right.
Logged
1968 RS 327 4 speed
Hero Member
Reply #4 on:
June 22, 2020, 12:17:16 PM »
If your only issues with the original core support is rotted mounts (especially the one under the battery), then I agree with Kevin.. just replace the mounts. I was able to find a good original one to replace the one under my battery (which was my only problem)...
Logged
Print
Pages: [
1
« previous
next »
Restoration
