Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
69 RS Camaro hideaway headlight Vacuum tank
« previous
next »
Print
Pages: [
1
Author
Topic: 69 RS Camaro hideaway headlight Vacuum tank (Read 2523 times)
67GTX
Newbie
on:
June 02, 2020, 10:55:55 PM »
I have two tanks, 1 has two vacuum ports on the tank and the other has one.... the brackets are different and in different locations....
I'm Restoring my 69 SS/RS Pace car Convertible tribute car, and would like to know which vacuum tank is correct.
Can anyone help me?
Tweet
Logged
CRG Member
Re: 69 RS Camaro hideaway headlight Vacuum tank
Reply #1 on:
June 02, 2020, 11:58:00 PM »
The 2 port is '68. Changed to 1 for '69.
Don't even bother trying to re-use an original valve. Get the OER repro.
Logged
67GTX
Newbie
Reply #2 on:
June 05, 2020, 11:37:28 AM »
Thank you for your info,I am having trouble trying to find the hole in the firewall where the groment that the 2 vac lines that go
to the headlight switch,it doesn't show in the assembly manual either,can you please help,thanks
Logged
Dusk Blue Z
Member
Reply #3 on:
June 05, 2020, 11:56:04 AM »
The grommet for the two vacuum lines going to the headlight switch is to the left of the grommet with the two wires for your cowl induction hood.
Logged
1969 Z/28 Legends Certified
1969 Z-10 Under Construction
BillG
Member
Reply #4 on:
June 05, 2020, 11:56:35 AM »
You said the car is a "tribute". Was it originally a Ralley Sport? If not the factory hole will not be there,
Logged
Bill Garrett
67GTX
Newbie
Reply #5 on:
June 05, 2020, 02:15:56 PM »
Yes it was a RS /SS convertible car,just paint was reverse of the pace car,orange /white stripes
Logged
Print
Pages: [
1
« previous
next »
Restoration
