Author Topic: 69 Camaro console water temperature gauge issues  (Read 4137 times)
mmotley
« on: May 17, 2020, 12:18:30 AM »
Hi Folks,
Hope you can provide some insights.   69 Camaro RS 4 spd with console gauges.   The water temp gauge will not come off cold regardless of engine temperature.   When the sending unit wire disconnected and ignition on the gauge goes to full cold.   With the sending unit grounded to battery and ignition on it goes to full hot.  This leads me to presume the gauge is ok and the wiring is properly hooked up.   I've cleaned all connections, confirmed ground, replaced sending unit, confirmed resistor on back of gauge is 85 ohms.   Resistance on the sending unit drops as engine temperature increases.   Here is the kicker - with the engine running and warm the gauge is at full cold - turn off the engine and ignition off and the gauge will begin creeping up.   Turn the ignition back on and it goes to full cold.   It makes me think I've got a short in the system somewhere and I'm getting battery voltage even with the key off.   I am not an electrician and have no idea if that makes sense.  I would think if I have a positive short things would melt or pop fuzes... but there is no way an electric gauge can move without electricity.  I'd appreciate any thoughts or suggestions you folks may have
thanks
Re: 69 Camaro console water temperature gauge issues
« Reply #1 on: May 17, 2020, 03:20:57 PM »
Sounds like you have an idiot light sending unit.
Have you checked the range of output from the sending unit using an ohm meter?
Does the output incrementally change or is it OFF or ON.
« Reply #2 on: May 17, 2020, 06:00:09 PM »
James is on the right track; Start with the Grounds at the console make darn sure they are good.
Then like James mentioned set up an ohm meter on the sender, Disconnect the harness green wire, Hook Red meter lead to the pin and black meter lead to chassis or eng ground. set  the ohm meter to read OHMS
In general terms:
Cold <400 ohms
Mid= 100 ohms
Hot around 50 ohms
These values are a ROM (Rough Order of Magnitude) i.e. approximate (* I can not recall where I source these values)
Start the car and warm it up observing ohm meter and monitor temp using a harbor freight point and shoot thermal device.
https://www.lectriclimited.com/electrical-devices/temperature-sending-unit-110014
If you get REAL fancy you can source a 0-500 ohm potentiometer and make a sender simulator.
The intent s to determine "IF" your sender is a variable resistor with inverse proportional resistance to temperature. See the temp increase the resistance decrease -vs- a std dash light "Switching" sender that is Open (Infinite ohms) cold and Closed (Zero Ohms) hot.
mmotley
« Reply #3 on: May 18, 2020, 12:08:45 AM »
Thanks for your help guys!!!
Clip on top - not threaded.   Stone cold it is 142 ohms - so pretty sure it not an idiot light otherwise it would read open.   I will crank tomorrow and check resistance as things warm up.   What about the gauge creeping up when the ignition is off?  Makes no sense to me.   I read though a crap load of forums and didn't see any issue similar to this.
« Reply #4 on: May 18, 2020, 02:44:44 AM »
I have a email to Lectric Ltd, & Found a Instrument Panel - with gauges color diagram dtd 2005
WATER TEMP SENDER
390 Ohms at 100 degree F
102 Ohms at 260 degree F
Your Stone Cold (Ambient garage temp) resistance seems out of wack?
396 SS/RS
« Reply #5 on: July 26, 2022, 05:22:18 PM »
I have a similar issue with my '68 SS/RS. The gauge sits far left. When shorting the green wire to ground it goes full and returns to full cold when ungrounded. I installed a new AC/Delco temp. sensor and issue still exist. I tested the original sensor with a heat gun and Fluke meter and ohms decreased as expected. I will check for a good ground at the gauge but it seems to me it should be good since the gauge pegs when grounded.
Good Judgment Comes From Experience, Some Experience Comes From Bad Judgment.
396 SS/RS
« Reply #6 on: July 27, 2022, 12:19:23 AM »
I found the ground wire screw in the gauge assembly loose so I tightened it, and still no operation. I jumped the ground wire to the shifter to ensure a better ground and still no operation. I also saw no drop on the voltage gauge when activating the headlights so I guess I’ll have to pull it all out and investigate further.
396 SS/RS
« Reply #7 on: August 04, 2022, 01:32:03 PM »
I resolved my issue. I found the horn relay mounting screw loose. I was perplexed as I had verified the gauge went full hot when grounded. 12v on green wire with switch on and verified continuity from sensor to the block. I was out things to test and it was suggested on another forum to check the horn relay bus bar and that was the issue. It’s the simple things (ground gremlins) that get you.
