Author Topic: Fuel Sending Unit Details - Tape and Sleeve  (Read 8777 times)
Edgemontvillage
« on: May 11, 2020, 07:45:21 PM »
For the 3/8" single fuel line on my '69 Z, the pipe terminates at the top of the rear frame rail then connects via a 5" rubber hose to the fuel sending unit. The sending unit's fuel pipe is secured, in part, by the fuel tank strap where there is a pinch point between the tank and strap (see photo and AIM diagram). At this position the sending unit pipe is protected by a rubber sleeve covered by tape (see AIM Parts #5 & #6.). During the disassembly of my project I took photos of the sleeve and what was left of the tape. I assume the tape is a crepe style as was used elsewhere during the assembly process. Does anyone have better information on the tape used on the sleeve?
Pinch point securing sending unit pipe showing protective rubber sleeve and tape remnants prior to disassembly
Sending unit pipe, sleeve and tape residual following removal of the fuel tank
« Last Edit: May 11, 2020, 08:09:21 PM by Edgemontvillage »
169INDY
Re: Fuel Sending Unit Details - Tape and Sleeve
« Reply #1 on: May 11, 2020, 10:19:54 PM »
I still have been looking for the spoiler tape.
Take a peek at 3M Temflex Friction  1755
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
R68GTO
« Reply #2 on: May 11, 2020, 10:38:44 PM »
Here's some pics of my isolator and tape.
1969 427 COPO Camaro Lemans Blue/Black, M22 4 speed, 15,500 original miles
Edgemontvillage
« Reply #3 on: May 11, 2020, 11:06:54 PM »
Excellent photos and details Jim, good foresight in taking the time to document this detail originally and thank you for posting.
From the photos it appears the tape is plastic-electrical or asphalt based?
169INDY
« Reply #4 on: May 11, 2020, 11:30:33 PM »
The Lighter strata layering (Wisps of white or beige) suggests paper or cloth (?) rather than "pure" vinyl or rubber
68 Z28 M21 LOS
R68GTO
« Reply #5 on: May 12, 2020, 12:48:23 AM »
Here's a better shot of the underside of the tape.  I couldn't take a close enough photo to show the fibers but the thin hair-type fibers run perpendicular to the length of the tape.  Also included pics of the tape that holds the sending unit wire to the top of the tank - it's the exact same stuff.  Wanna know more details on my tank, let me know - I have pics of the mastic glue smears used to hold the pads and pics of the steel supplier stencil also.
R68GTO
« Reply #6 on: May 12, 2020, 12:49:12 AM »
couple more...
Edgemontvillage
« Reply #7 on: May 12, 2020, 03:23:12 AM »
More good photos, thanks. Jim, does the tape look like anything that's commercially available currently?
169INDY
« Reply #8 on: May 12, 2020, 03:50:20 AM »
I should have my hands on 3M Temflex Friction  1755 by next week.
Sample of (Photos) 1968 LOS Dec 67 build L35 Car
68 Z28 M21 LOS
ZLP955
« Reply #9 on: May 12, 2020, 06:49:07 AM »
Interesting clip to the left of the sleeve in Jim's last picture above.
Tim in Australia.
« Reply #10 on: May 12, 2020, 01:29:15 PM »
Looks like a typical fuel line clamp, used farther down the line.
ZLP955
« Reply #11 on: May 12, 2020, 01:55:21 PM »
Interesting in that location
Tim in Australia.
169INDY
« Reply #12 on: May 12, 2020, 03:36:45 PM »
The REPOP clip was put on years ago when a Kinked Fuel line rubber hose was presenting a fuel delivery issue, the clip must have slid over during the removal. Tank was removed and on the ground at this point.
68 Z28 M21 LOS
R68GTO
« Reply #13 on: May 12, 2020, 11:55:15 PM »
I have never searched for a filament type tape like that.  I compared my electrical harness tape to the black side of this tape and while different, you had to look really close to see the difference.  Given the location of this part, I just wrapped it with that.
« Reply #14 on: May 13, 2020, 02:41:54 PM »
On corvette vacuum headlamp hose bundles and on a few places on the wire harness there is a tape used to bundle things together which appears on the adhesive side like friction tape but has a black smooth front surface, (like harness wrap or electrical tape but this black smooth front is only a fraction of the thickness of electrical tape or harness wrap.)  (not to be confused with the fiberglass filament tape used at the vacuum "T's".)
NO ONE ON THE NCRS boards had found a suitable replacement as of last year.
I replaced a couple of sections and used friction tape of the correct width combined with 1/2 mil black plastic cut to the correct width as the tape .
Does this appear to be the same type of tape as on the sending unit wire?
