Author Topic: Washer pump issue  (Read 2593 times)
dalekerr
Washer pump issue
« on: May 03, 2020, 03:46:17 PM »
I recently replaced my wore out washer pump with an after market replacement it worked fine for a few days, then it sprayed whenever the wipers were turned on. I unplugged the wires to it, made no difference, still sprayed when wipers were running.
. So I sent the pump back an purchased an NOS unit, installed same issue 1967 with 68 style pump. What am I doing wrong?
Thanks Dale Kerr
Dale Kerr
1967 Y 2 350 M20 12 Bolt Vintage Air
03D
dalekerr
Re: Washer pump issue
« Reply #1 on: May 04, 2020, 01:30:15 AM »
Please, I need some help. How do you bolt the new style washer pump to the 67 wiper motor? The units came with no instructions and the holes don’t line up. There must be trick to make this pump work on the 67, since all the suppliers carry this unit for 67 models. I replaced two of these on 68 models with no problems.
Dale Kerr
03D
« Reply #2 on: May 04, 2020, 12:27:41 PM »
67s used a unique wiper motor that does not interchange with 68-69.
Petes L48
« Reply #3 on: May 04, 2020, 10:13:44 PM »
Is your old pump repairable?  I found that the bellows kit from a 67 Vette is the same for 67 Camaro.  I also found a spare kit on eBay, see picture.  Someone also told me/claimed they were able to put the newer 68 up pump on a 67 wiper assembly, by drilling a new mount hole for one of the three(?) screws.  No idea if true.
https://www.paragoncorvette.com/search.aspx?Year=1967&SearchTerm=washer+pump
http://gmpartswiki.com/getpage?pageid=78053
dalekerr
« Reply #4 on: May 04, 2020, 10:49:54 PM »
The old pump will not engage, I’m sure it is an electrical problem. Maybe I can play with or take it to a local alternator shop and have them fix it.
Thanks for the help.
Dale Kerr
03D
