Author Topic: 1969 ignition coil  (Read 6654 times)
TonyS
1969 ignition coil
« on: April 13, 2020, 01:21:27 AM »
Anyone have a source for a coil for the cowl hood application? I hope this is the #270? I have one on order from Ecklers, but maybe another week or more before it ships, since they are currently out of stock.
What is the difference in the cowl hood/non-cowl hood coils?
Thanks.
Tony
Re: 1969 ignition coil
« Reply #1 on: April 13, 2020, 03:17:48 AM »
Z/28 and SS350 used the 270 coil assembly to move the coil away from the air cleaner. 396/427 didn't require it.
The mounting bracket is the same one used on the '65-'67 275/327.
TonyS
« Reply #2 on: April 13, 2020, 03:30:16 AM »
So the bracket is different, but the coil should be the same physical size as a flat hood car? This is what I think, just want to be sure.
Thanks.
Tony
« Reply #3 on: April 13, 2020, 05:50:59 AM »
Yes.
« Reply #4 on: April 13, 2020, 07:15:10 PM »
Some service replacement coils are larger in diameter than OE and had ink-stamped characters.
OE was 2.125" dia with stamped, raised characters.
TonyS
« Reply #5 on: April 13, 2020, 08:50:46 PM »
Thanks gents.
Tony
« Reply #6 on: April 15, 2020, 01:12:57 AM »
Try Long Island Corvette Supply if your coil is still on b/o.
« Reply #7 on: April 15, 2020, 01:20:38 AM »
Disreguard, 63-67. Where I picked up my 202 coil.
Sorry, bad info.
hugrz28
« Reply #8 on: April 15, 2020, 05:09:16 AM »
I have several, contact me if you are interested.
Dan
