Author Topic: Manual steering gear fluid  (Read 5683 times)
JKZ27
« on: March 26, 2007, 02:13:10 AM »
Anyone know of a good oil to use in a manual steering gear since the GM stuff is discontinued. Mine has been leaking for a while.
John
John
68 RS Ash/Ivy Gold 327EFI M20
Re: Manual steering gear fluid
« Reply #1 on: March 26, 2007, 03:02:51 PM »
Well, It's actually grease.  I just had mine rebuilt by Pro Steering and some other people on TC used them too.  I asked them and they use Valvoline Multi Purpose grease # 612.  Jerry MacNeish rebuilds them too.  If yours is leaking, I'd get it fixed.  Mine had to have the whole inside replaced as it leaked out and the inside looked like it had mud in it.  I don't know if Jerry sells seals or not.  www.prosteering.com and Jerry is www.z28camaro.com
Wallace
« Reply #2 on: March 27, 2007, 07:52:22 PM »
I recently went through a '70 manual steering gear and was able to locate both seals, but the flat gasket that goes under the adjusting plate (with three bolts) was unavailable.  I did a clean prep and used permatex instead of the gasket.  I packed the bearings, worm gear and the entire case with Mystik JT-6 grease.  It took most of the 1 pound can, and so far no leaks.
Wallace
JKZ27
« Reply #3 on: March 30, 2007, 03:16:15 AM »
Thanks guys, I didn't think of grease.
John
John
