Author Topic: Original GM Trans-AM Second Gen GM Coil Springs?  (Read 2605 times)
mikebaronehouston
« on: April 04, 2020, 12:58:32 PM »
I have a set of springs which supposedly came from the Hall Chaparral collection.
Part number is X779B440.  I was told this was an experimental GM number. Presumably they are 440#.  I had them tested at an oil-field spring facility--426# and 430# respectively on a very cool compression machine.  Crazy cage around it; I suspect they do so big springs...
Dimensions are .711 wire, 9 coils and 16” free.   I am not sure of the compressed height between the spring pocket and lower A-arm; I'll measure today.
Anyone have a way to decipher and confirm/deny the part number?
Mike Barone
Houston, TX
Re: Original GM Trans-AM Second Gen GM Coil Springs?
« Reply #1 on: April 05, 2020, 12:46:21 AM »
That does not look like a GM part number unless the B is really an 8 however I got no results when I did a search for 7798440.
crossboss
  • ^ New engine project
« Reply #2 on: April 05, 2020, 03:51:38 PM »
Mike,
Most likely the springs were made by an out sorced vendor.
1968 Olds 442 W-30
mikebaronehouston
« Reply #3 on: April 06, 2020, 05:32:28 AM »
Many thanks.
Now I can cut-to-fit without reservation!
Mike Barone
Houston, TX
crossboss
« Reply #4 on: April 08, 2020, 05:18:37 AM »
Mike,
Sorry we did not meet up in Houston and check out our cars. IF you plan to travel to Vegas, send me an email.
-Scott.
1968 Olds 442 W-30
