Author Topic: '69 Z - Block Stampings?  (Read 4681 times)
Hans L
« on: March 07, 2020, 04:49:54 AM »
How do these engine stamps look?  Claims the block has been lightly decked...
https://www.ebay.com/itm/333533667660
'69 Chevelle SS 396 4 Speed
Stingr69
Re: '69 Z - Block Stampings?
« Reply #1 on: March 07, 2020, 06:09:42 PM »
The heads are not original as they started out life as small valve heads.  The combustion chamber has not been unshrouded as it would have to be if they were original big valve heads.  Valve covers are reproductions.  Bob does know these things but he fails to mention it.  I am not surprised.
Difficult to say much about a fresh decked block.  Can not be proven either way now.  Bob would have taken a picture of it before decking if it was in his hands at the time.  He did not post a picture of that so he does not have one.  It will forever be in question.
Looks like a real Z/28 to me from what I can see there.   That is a lot of money for a project.
rszmjt
« Reply #2 on: March 07, 2020, 11:44:05 PM »
I noticed that the heads are converted 1.94/1.50 heads too, the thicker area between the intake valves is a giveaway because of no chamber machining around int valves. Good eye Stingr69. FWIW That block is not freshly decked IMO, looks like very old machine marks, there are things about the stamp that are not normal also I think.
« Reply #3 on: March 08, 2020, 01:36:51 AM »
JMO, but I can lend a little support for the decked block - looks like the milling pass was light, some removal above the numbers (especially the 3) caused them to appear shallow, sharp faced stamps, plus the different fonts have been seen before (replaced in the set due to wear, breakage, loss). I wouldn't count it out -
« Reply #4 on: March 08, 2020, 01:59:03 PM »
The Vin stamp on the trans and the engine have different individual stamps trans has flat top 3's and the engine has round top 3's and the 2 is not the same at first glance... not saying it's not original HOWEVER - it should be checked.
rszmjt
« Reply #5 on: March 08, 2020, 06:20:51 PM »
Thanks James.
If the trans stamp vin and block vin are different characters then I suspect 1 of them is a restamp. Apparently the block & trans vins were done at the same time with the same loaded gang holder and characters so how could they be different? The trans stamps certainly look original?
As far as the Flint block build stamp characters, I have seen different fonts before but I’m guessing its not the norm, I think it has other issues too.
Anybody have any pictures from the same month to compare ?
« Last Edit: March 08, 2020, 06:46:26 PM by rszmjt »
Hans L
« Reply #6 on: March 08, 2020, 07:41:22 PM »
Here's mine, March dates, but LA built.   Trans and Engine VIN stamps are identical.  Round "3's"
« Reply #7 on: March 08, 2020, 10:18:22 PM »
Hans I have V0321DZ and the partial also has the large '2' which I've seen on at least one other LA car from that period.
« Reply #8 on: March 08, 2020, 10:25:34 PM »
It is not unusual for Norwood engine/trans VIN stampings to differ.
« Reply #9 on: March 09, 2020, 02:07:44 AM »
That is an original stamp on the pad.
124379N623533
rszmjt
« Reply #10 on: March 09, 2020, 02:45:27 PM »
Thanks William ,
 So Norwood workers could have used 2 different holders with different characters\ fonts?
« Reply #11 on: March 09, 2020, 03:05:41 PM »
They did use different stampers, probably done at different points during final assembly.
« Reply #12 on: March 09, 2020, 04:24:15 PM »
The one off of my old 69 Z. October 1968 Norwood flat top 3's
« Reply #13 on: March 09, 2020, 04:27:37 PM »
Yes, we sometimes see the different fonts and we don't know why. These VINs would have been stamped on the engine dress line. I was involved in engine dress lines in several plants and I surprised that two different stampers were sometimes used...
rszmjt
« Reply #14 on: March 09, 2020, 07:34:57 PM »
Most known original Flint stamps are higher on the pad towards the Intake flange, this Ebay stamp appears like it is centered on the pad that's why I was questioning it. I know they were applied by workers but did this occur more?
