Author Topic: Turn signal shaft knob?  (Read 1981 times)
Tinkerr
« on: November 19, 2019, 10:08:53 PM »
I bought a NOS turn signal shaft 3909580 for my 68 Camaro. I need to install the knob, after I paint it blue, black is all that's available. I thought the knob was pressed on the stalk, but the one I ordered just drops on with no resistance. Are they glued on? The diameter of the knob is a tad larger where it meets the shaft. Is it supposed to be a flush, smooth transition to the shaft? Thanks Paul
I did a search, not much on the tantalizing topic of turn signal shafts.
Re: Turn signal shaft knob?
« Reply #1 on: November 20, 2019, 01:13:49 AM »
I would wonder why they did not mold it with a slight interference fit for a press fit for tightness, figures.
Could you just use a quality two part adhesive meant for bonding metal-plastic-rubber? Such as a Loctite or Permatex product found locally.
Follow up Q.
Can a badly pitted original be chrome plated to renew the stalk finish?
I have heard the shape of repops and originals are different?
JIM
Tinkerr
« Reply #2 on: November 20, 2019, 01:21:59 AM »
I believe a 2 part epoxy would work. I wasn't sure if the poor fit was because I purchased a poor reproduction knob or that is the way they are all made.
I'm sure you could have a original rechromed, but NOS(service replacements) are readily available on E-Bay for $20 or so. Either way you would be where I am, attaching a repo knob. Thanks Paul
« Reply #3 on: November 20, 2019, 06:28:09 AM »
I like weatherstrip adhesive for that kind of joint. Epoxy should work too.
