Author Topic: 68 Camaro 6 cyl to BBC conversion  (Read 12769 times)
warnergn
  • Greg
« on: October 14, 2019, 12:34:10 AM »
Hi all.  Long story short, I was sold a car that was described to be a BBC 427 Camaro but after closer inspection I believe I was taken to the cleaners.  Too much time has gone by now to do anything about it.  But, I am just moving forward and planning to now make it what it had been claimed to be.  I have some questions though.  How much is involved in switching over an auto 6 cyl Camaro (thinking worst case scenario for reasons later to be described) to a BBC with 4 spd?
Negatives:  I've found the rear to be non-posi, it has drum brakes front and rear, no trim tag, and the VIN appears to be altered from a 123367 to a 124367.  Also, there is no tach but there is a console with no gauges.
Positives:  The body is in nice shape, it has a BB with factory manifolds, a Muncie M21, houndstooth interior, RS headlights and backup lights, Z hood, new tires and Ralley wheels all around, new exhaust, and all new trim.
While trying to get the car inspected it was discovered that the engine was never bolted to the chassis - both sets of mounts are there on the frame and the engine - they just stuck the bolt through and called it a day.  Also, the Hurst shifter is short and makes for a reach to shift to 1st and 3rd.
Right now I am debating whether to remove the engine so that I can verify whether or not it is a 427 or a 396 - the numbers have been ground off of the pad on the front of the engine.  The intake is also a no-name alum intake or all identification was ground off of it as well.  The carb that came with the car was an old dirty Edelbrock 1404 - I have since installed a new one (1406) but if this is indeed a 427 I'm thinking I should have sprung for a 750 Edelbrock (due to the "4-hole" configuration).  The distributor is a GM 10093387 heavy duty unit mated to an older MSD box (not even a 6AL).  I have already replaced the shocks all around, added a fuel pressure regulator, a complete rear wiring harness for an RS, new plug wires, just bought a GM HEI but haven't installed it yet, and new console gauge package with Tic-Toc-Tach.  I also bought a 8.5 10-bolt posi rear for it - have 3.55 gears to install.  The clutch rod is extremely loose and has actually fallen out a time or two (in the garage, not while driving) - which has me wondering if the Z bar is correct for the BBC or if the mounting holes on the frame are wrong (remember I'm not sure if this was a 6 cyl or a SBC car to start) - after doing some reading I understand that the correct Z bar would need to be in place for the clutch to work properly/safely - the clutch rod is adjusted out as far as it can go.
All this to say:  Does anyone have any pointers or experience converting from a 6 cyl or SBC to a BBC?  I don't intend to ever sell this car or claim that it started out as a BBC car with all the bells and whistles - I just want to drive the dang thing and make it into what I thought I was buying.  Does the under dash wiring harness need to be swapped out to mate up to the wiring harness that came with the new gauges and tach?
Thanks for any and all thoughts, suggestions, criticism.
Greg
'68 RS/SS 427 4spd Jet black/white stripe
Re: 68 Camaro 6 cyl to BBC conversion
« Reply #1 on: October 14, 2019, 04:47:35 PM »
Greg, it appears you have a huge can of worms. Swapping engines isn't a big deal, but you need the right parts. IF you already have the big block mounts, than all you need to do it just bolt them in. If not, they're available reproduction. The numbers may have been machined off the front pad, but what about the casting number on the block itself? If that's still there, it may help narrow it down to what it is.
Installing gauges requires the correct wiring harness, but an "adapter" harness is available aftermarket to add them to cars that didn't come with them in the first place.
I'm not going to get into the legalities of tampering with a VIN (a Federal offense), but I highly recommend you contact your local authorities to have them inspect the car. Hopefully, it's not stolen.
« Reply #2 on: October 15, 2019, 03:40:44 AM »
Greg,
I agree with Ed - multitude of things going on with this car, check the VIN in the other locations on the car against the VIN tag, and see if they agree with the (altered?) VIN, that should tell you what the car is VIN'd for. If it is different, call the law into play. Hateful to see someone taken advantage of -
Ditto on Ed's statement about the engine mounts, make sure you have the appropriate big block crossmember, and the right Z bar clutch linkage - SB and BB are different. All of this is available as reproduction -
Change the Hurst handle on the shifter, if it's a Competition Plus aftermarket shifter, the handle bolts on. Replace it with a Hurst standard shift handle with the right length - eBay stuff.
By the way, is this a '67 or '68 ? You mentioned '68, then stated a '67 VIN. Post pics of the block casting number, and heads, we can likely figure out the displacement.
« Reply #3 on: October 15, 2019, 09:32:36 AM »
You may be questioning now your Z bar and engine frame stands. The difference in a bbc z bar and the other(sb & 6 cyl) is a 1/2”. Bbc 9 1/2” sbc & 6 =9” . If you have a 9 1/2” (you can measure that in the car), most probably then, the frame stands will be correct. So you can figure that out pretty quick. Is the z bar coming out of position or is it that the adjusting rod is falling out of the clutch fork? Could be an adjustment or wear issue. If you tell us where you live , perhaps a knowledgable member could evaluate you car and the issues you have.
Let me take this opportunity to welcome you to this informative site.
warnergn
  • Greg
« Reply #4 on: October 15, 2019, 11:34:42 AM »
Yes, can of worms is correct.  I tried maneuvering the block into the brackets without success.  The power steering unit is against the exhaust manifold and I was thinking that maybe the Z bar is holding it up as well.  I'll check the numbers on the back of the block tonight.
I'll likely be picking up whatever harnesses and adapters are necessary for a cleaner installation.
I didn't really take notice to the VIN until I looked closer - I will try to attach a pic but so far every time I try to add a picture it turns out to be too large to download.
Thanks, for your thoughts...............oh, and I completely misprinted the VIN - it's 124378, not 124367...............sorry about that. :-\
warnergn
  • Greg
« Reply #5 on: October 15, 2019, 11:41:26 AM »
Greg,
Hi Steve,
Yes, I'll be checking other VIN locations to verify this.
I believe the engine mounts are correct but I'll try to verify that as well as the Z-bar clutch linkage.  I wasn't aware that the cross member was different - I actually unbolted it at the transmission and loosened all 4 of the side bolts in order to move the engine into the mounts.
I did mess up the VIN, sheesh!  It's 124378, not 124367.
Thanks!
warnergn
  • Greg
« Reply #6 on: October 15, 2019, 11:49:05 AM »
I will try to measure the Z bar - it's awful tight and will be tough to measure but I'll give it a try.  I don't think the Z bar is moving, but the adjusting rod falls out of the clutch fork.  I looked for longer ones but that's not the true fix.  I need to make the one I have work properly rather than "bandaiding" it.
I live in the southcentral PA area.  I owned a 69 RS/SS 4-spd for nearly 30 years before (unfortunately) selling it.
Anyway, I look forward to this site's help and wealth of knowledge.
Greg
« Reply #7 on: October 16, 2019, 03:31:59 AM »
Greg,
I forgot to welcome you to the site - you'll find just about every topic you can imagine on here, sure does answer a lot of questions to most owners and enthusiasts. I just thought I knew a lot about first gen Camaros until I joined the CRG. Learn everyday -
Do yourself a favor - download Light Image Resizer from the net (free for the first 100 picture resizings). Easy to use, it will resize to what you need to post with just a few keystrokes. I've utilized it a lot in the past before I broke down and bought a newer iPhone that allows me to size the pic when I'm sending it to file.
Sounds like you are on the right track. Wrong frame mounts will cause a host of problems, I wouldn't be a bit surprised if they were 6 or SB mounts considering the pinch on the steering box. Remember to add the spring to the Z bar (which is also different big to small block). Host of vendors to buy from, you'll find most of them mentioned here in multiple threads.
warnergn
  • Greg
« Reply #8 on: October 16, 2019, 03:42:34 AM »
OK, I think I finally figured out how to post a pic of the partial VIN here.  Let me know if you think it is legit or altered.
Greg
« Reply #9 on: October 16, 2019, 11:47:44 AM »
altered.
warnergn
  • Greg
« Reply #10 on: October 16, 2019, 12:22:31 PM »
altered.
Seems like this car is marked for life then.  Do you know that this car was actually appraised and this wasn't picked up, nor the missing trim tag, the engine not bolted down, non-posi, non-working brake lights or back up lights, etc.
Sheesh!  What to do, what to do.  :-\
Greg
Kelley W King
« Reply #11 on: October 16, 2019, 12:39:16 PM »
hopefully you did not pay the price for a proper BB 68.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #12 on: October 16, 2019, 01:17:38 PM »
Yes, the VIN appears to have been messed with (the 4 is really funky), but I don't see any remnants of a 3 under it, so I'm not so sure it's NOT an original V8 car. What's the complete VIN? Can you email me a better high resolution picture of the VIN? My email address is in my signature below.
« Reply #13 on: October 16, 2019, 04:17:48 PM »
Who appraised the car? I would like to see the report. And I can recommend an attorney for the situation you are caught up in.
This car had a 10 bolt rear end? All SS cars in 68 had a 12 bolt rear end.
Trim tag missing?
1968 differences at this link.
http://www.camaros.org/diffs68.shtml
« Reply #14 on: October 16, 2019, 05:24:31 PM »
What VIN is on the title?
