Author Topic: 1969 broardsheet codes 5AO14A and 5Z11AA ?  (Read 8919 times)
Re: 1969 broardsheet codes 5AO14A and 5Z11AA ?
« Reply #15 on: June 23, 2019, 04:18:04 AM »
Body number (from the trim tag) would be unique to a LOS-built car, or do you mean a firewall crayon sequence number, often 3 digits?
« Reply #16 on: June 24, 2019, 01:18:53 AM »
The 'crayon marking' as the body moves thru the plant is generally referred to as 'sequence number'... as in my Camaro has '18' on the LHS shoulder (under the fender)...
« Reply #17 on: June 24, 2019, 06:53:21 PM »
Not for 1969. Both plants were on the same order entry system.
« Reply #18 on: June 25, 2019, 03:11:17 AM »
Yep that didn't come across as intended; what I meant was that LOS production ended well before NOR production saw the body numbers reset around the (anticipated) end of model year, and so there couldn't be 2 LOS '69 Camaros with the same body number, unlike NOR.
wono427
« Reply #19 on: June 25, 2019, 05:52:28 PM »
Hi I am referring to the one letter 3 numbers stamped
on the body tag , not the body VN number on the same tag
On The damaged broadsheet I have , the box before where the serial number would be looks to have the same 3 numbers but no letter
It very hard to see and am trying to get better photos
To post
Thanks for the help
« Reply #20 on: June 26, 2019, 01:10:17 AM »
Would that be the projected build week??
wono427
« Reply #21 on: June 26, 2019, 06:47:51 AM »
P165 is the stamping  on trim tag -build date is 24/4/1969 from NCRS
« Reply #22 on: June 26, 2019, 09:43:01 AM »
LOS Body scheduling code: http://www.camaros.org/numbers.shtml#b
« Reply #23 on: June 26, 2019, 12:51:58 PM »
P165 =    P represents the 21st of April (assuming April is the month the body was built);  The 21st of April is the 16th production day (corresponding to the P).    165th body to be built that day...   so body was built 3 days prior to final auto assembly completion day (24 April)...
if I did this right??   I don't normally see LOS cars in my area...
« Reply #24 on: June 26, 2019, 12:53:59 PM »
Approximately 16th day of production for the month.  165th body for the day.
« Reply #25 on: June 26, 2019, 01:01:49 PM »
You're right Bryon!~   :)
seems I can't count on my fingers!!  :)
I corrected my post...
« Reply #26 on: June 26, 2019, 01:17:34 PM »
It’s ok Gary, I had to check and then re-check myself - twice!
« Reply #27 on: June 26, 2019, 02:28:24 PM »
In the Engine RPO box there is a single letter... should be a G.
G = 302
wono427
« Reply #28 on: June 27, 2019, 10:58:52 AM »
Can’t read RPO box
wono427
« Reply #29 on: July 04, 2019, 05:21:03 AM »
trying to read sequence numer box
