Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
COWL HOOD FRAME
« previous
next »
Print
Pages: [
1
Author
Topic: COWL HOOD FRAME (Read 2230 times)
ALLZS
Member
COWL HOOD FRAME
on:
January 14, 2019, 02:06:32 PM »
is the 69 Camaro and the 70 chevelle cowl hood flapper frame the same part
Tweet
Logged
Mark
CRG Member
Re: COWL HOOD FRAME
Reply #1 on:
January 15, 2019, 09:04:29 PM »
No, the 70 chevelle SS was a vacuum operated deal as i remember. I had a 70 Chevelle SS and the flapper would open and close at idle if you had a big Cam in the engine.
Logged
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Stingr69
Hero Member
Re: COWL HOOD FRAME
Reply #2 on:
January 16, 2019, 05:05:32 PM »
The '69 ZL2 cowl induction electric solenoid is a common part that was also used on 70's Corvettes. Not sure if the frames will interchange but you can take a run at it. The smog era Corvette pieces are much cheaper than the '69 Z/28 pieces even if they are the same part number.
Logged
Print
Pages: [
1
« previous
next »
Restoration
COWL HOOD FRAME
