Author Topic: Chrome Shift Ball 1969  (Read 9765 times)
« on: December 23, 2018, 11:02:08 AM »
I believe this to be an original. Anyone see anything to the contrary?
Was this shift ball used on any other car and any other year besides the ‘69 Camaro? I know a 5/16 pitch was used on 67-8. Only talking this exact part. Thanks.
1969 69 Camaro Shifter Chrome Ball  3/8" Shift Handle 4 Speed Original OE Knob https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F173702990259
X33RS
Re: Chrome Shift Ball 1969
« Reply #1 on: December 23, 2018, 03:09:26 PM »
I have a complete 70 Z/28 shifter assembly with body, rods, stick and ball.  It has the exact same ball that my 69 Z has on it.
« Reply #2 on: December 23, 2018, 03:44:39 PM »
Really? $100 bucks for an old beat up shifter handle that needs a TON of work???
While I'll admit, it's a better price than THIS ONE for $379, IMO, get a repop instead. Once it's installed you can't tell the difference and you'll save yourself a TON of money!
« Reply #3 on: December 23, 2018, 05:54:07 PM »
I agree with Ed.
« Reply #4 on: December 23, 2018, 06:57:59 PM »
Looks like someone thinks it worth the asking price. Supply & demand.
« Reply #5 on: December 23, 2018, 07:07:25 PM »
Well, considering there are dents and gouges in it, it would need to be turned, then rechromed. Turning it will reduce the original diameter so it won't be "original" anymore! Machining, then rechroming will add another $150 or so, probably more, so why bother to buy an original knob for $100, only to have to put more work and money into it, then lose points because it's not the correct diameter???
Quote
Note that the current bidder has 4 percent of his bids with the seller! I find that interesting.
But as I always say, it's your money. Do what you want.
« Reply #6 on: December 23, 2018, 07:44:58 PM »
I am sure there are one or two of those in a drawer in the shop at the farm.
« Reply #7 on: December 23, 2018, 07:57:31 PM »
If it's stripped and rechromed, then the 'initial copper coating' would be the stage that it would be filled/polished so no turning (and it's corresponding reduction in diameter) should be necessary...
« Reply #8 on: December 24, 2018, 01:17:25 AM »
I'm not sure the copper coat would fill in those dings and divots. And this is just 4 of the several I see in the pictures!
« Reply #9 on: December 24, 2018, 01:29:33 AM »
Hmmm user name looks familiar
« Reply #10 on: December 24, 2018, 02:26:59 AM »
They are on to me?
« Reply #11 on: December 24, 2018, 02:44:40 AM »
At least you got one reply to your actual question.
« Reply #12 on: December 24, 2018, 03:02:25 AM »
Yes we are on to you...
Well here is an answer...
If it is GM part number 3955766 - then that part number was used for all manual shift (3 speed and 4 speed) for Camaros that had a console in 1969 and 1970. This should be 3/8 threads. I am not sure if it was used for other applications in other GM cars.
« Reply #13 on: December 24, 2018, 03:25:13 AM »
Bentley, if this really is your auction (and it appears it is), and they don't back out of the bid, take the money and run!! (Or invest it in lottery tickets!)
« Reply #14 on: December 24, 2018, 10:49:30 PM »
Not sure either if used in other applications but Bentley, what is the weight and is it metal (magnet likes) or non? I had one years ago that looked the part but was not a real GM piece.
