Author Topic: zz502 into 69  (Read 3765 times)
69aus
zz502 into 69
« on: February 26, 2007, 04:41:16 AM »
Anyone done this transplant? Does the 502 sump fit and is there any other clearance problems when fitting to 69. Also are there any headers that will fit without adjustment ? Are the smallblock engine mounts ok ?
Thanks in advance
sdkar
Re: zz502 into 69
« Reply #1 on: March 14, 2007, 01:19:54 AM »
You can use either hooker headers (part # 2457) or if you have some extra money, go to Dougs headers (http://dougsheaders.com/tv/) for the 502 to fit in the 69 Camaro.  You will definitely need to change the oil pan to a 4 quart pan to clear the crossmember.  There is an oil pan offered that is specifically made for the 502 in a 69 Camaro.  Other than that, everything will fit fine.
sdkar
