Author Topic: Stock-Looking HEI  (Read 4659 times)
curtis0916
Stock-Looking HEI
« on: October 17, 2018, 03:58:43 PM »
I'm restoring a 1968 SS 396 to be mostly stock, but would like the advantages of HEI.  I have heard there are stock-looking HEI units available (mainly smaller cap), but have not been able to find one, and when I have asked suppliers they have no idea what I'm talking about.
Where could I get one of these stock-looking/small cap HEI's?
Thank you for any assistance you can provide!!
Kelley W King
Re: Stock-Looking HEI
« Reply #1 on: October 17, 2018, 05:57:17 PM »
Not sure about the stock looking HEI. I use the electronic conversion that fits under the stock cap with a HO coil. The coils are usually chrome or ?? but I just paint them black. Works pretty good.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
curtis0916
« Reply #2 on: October 17, 2018, 06:13:07 PM »
Thanks Kelley, the electronic conversion kit sounds like it might be a very good option.  What brand did you use?
« Reply #3 on: October 17, 2018, 06:18:42 PM »
I'm running the LECTRICLIMITED BREAKERLESS-SE™ system and love it. It's a single wire install so it appears "factory", and uses the stock coil and wiring, so it's plug-n-play.
Stingr69
« Reply #4 on: October 17, 2018, 06:33:46 PM »
https://www.davessmallbodyheis.com/
I actually have used a "Stinger" magnetic trigger conversion for a bit and now use the GM points (acting as a trigger switch only) with a Crane Multispark CD setup and stock coil.  The points electrical contact surfaces do not wear out because they only carry a small switch current this way.  I get an adjustable rev limiter with the Crane box so that is a plus. Box is mounted inside car under the center speaker grille.  Can set RPM limit to 2500 for "Valet Mode".  Pretty handy.
« Last Edit: October 17, 2018, 07:21:08 PM by Stingr69 »
Kelley W King
« Reply #5 on: October 17, 2018, 08:51:33 PM »
I used Petronics but the single wire Ed used would be easier to hide since mine is two wire. Either of them will probably do fine since they eliminate the resistor or resistor wire that points require. You might want to make sure whatever you use will work with your tach.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
« Reply #6 on: October 17, 2018, 10:18:23 PM »
 I thought the Electric Limited single wire unit stated the resistor wire can remain.
« Reply #7 on: October 18, 2018, 12:04:49 AM »
Quote
Yes. Everything remains completely stock.
