Author Topic: Camshaft  (Read 3269 times)
montgomg
Camshaft
« on: August 24, 2018, 04:11:37 PM »
I have a 69 Z28 with it's original 302. Before my ownership someone stuck a cam a bit different from the original Duntov 30/30 cam. Engine suffers from very low vacuum (5 in Hg) and in spite of advancing the cam 2 degrees and opening the valve lash the vacuum remains low. Good  idle is difficult to achieve and maintain and power brakes are also a bit of a problem.
   For you guys who run the Duntov 30/30 what kind of idle vacuum do you have and do you have your cam installed straight up or advanced? If advance how many degrees?
jdv69z
  • 69 RS Z/28 52E
Re: Camshaft
« Reply #1 on: August 24, 2018, 08:18:55 PM »
8-11 in Hg Std timing
Jimmy V.
Fred Mertz
Re: Camshaft
« Reply #2 on: August 25, 2018, 04:02:51 AM »
A shaky 7.  Advancing the timing helps a little.
