Author Topic: clutch  (Read 4692 times)
pjbizjak
clutch
« on: August 01, 2018, 06:54:34 PM »
hello all, what is the correct part# for a 68 z/28 clutch inspection cover?
Re: clutch
« Reply #1 on: August 01, 2018, 08:13:04 PM »
It's the same as all the other 3858403 bell housing applications, P/N 3788422.
Re: clutch
« Reply #2 on: August 01, 2018, 09:04:54 PM »
I can't find the threads, but isn't there a difference in the assembly-line cover and the one's available now?
pjbizjak
Re: clutch
« Reply #3 on: August 01, 2018, 09:15:12 PM »
I bought one on line that was supposed to be for 68 sbc camaro z/28 but the hole for the starter is to small. and it doesn't have the straight edge on the left.
Re: clutch
« Reply #4 on: August 01, 2018, 09:33:24 PM »
Yes, I've also heard that the later service replacements and repops are wrong. If you need a factory correct one you'll need to find a good used one. Shouldn't be too difficult since these things were used on a bizillion cars!
Re: clutch
« Reply #5 on: August 02, 2018, 02:01:55 AM »
Not to hi-jack but any reference to a picture with differences? I know it was discussed here many moons ago but I can't remember the topic.
Re: clutch
« Reply #6 on: August 02, 2018, 12:55:11 PM »
No, I've never researched this past the point of hear-say. Maybe someone else can help.
pjbizjak
Re: clutch
« Reply #7 on: August 08, 2018, 07:20:19 PM »
It's true, I also order one online(stated to be he correct one, nope! starter hole to small and mounting holes are off.  ordered one for the 10 1/2 clutch and 403 bellhousing and it works fine.
Pete
