Author Topic: brake booster  (Read 2737 times)
pjbizjak
brake booster
« on: June 21, 2018, 12:52:30 AM »
Hello, I just replace the power booster on my 68 Z and I want to remove the vacume connector and replace it with the born with connector and before I get to aggressive trying to remove it, I need some help in 'how to' do it.
Danzo
Re: brake booster
« Reply #1 on: June 21, 2018, 01:45:13 AM »
Just twist it out.
Re: brake booster
« Reply #2 on: June 22, 2018, 12:50:59 PM »
squirt a little WD40 on the rubber and it will be easier to remove.
169INDY
Re: brake booster
« Reply #3 on: June 22, 2018, 03:07:00 PM »
Lube with  isopropyl alcohol Twist and pull NO levers please (screwdrivers!)
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
Charley
Re: brake booster
« Reply #4 on: June 22, 2018, 04:25:06 PM »
Hopefully you didn’t put one of the cheap Chinese made boosters on.
Re: brake booster
« Reply #5 on: June 22, 2018, 10:09:26 PM »
What James said works very well.
Re: brake booster
« Reply #6 on: June 24, 2018, 12:00:04 AM »
I agree! When installing I use a light coat of dawn detergent for lubricant.
