Author Topic: Rear Axle Brake Line Clip PN# 3956700  (Read 19463 times)
Edgemontvillage
« on: June 03, 2018, 06:56:49 PM »
I'm reassembling the 12 bolt differential from my 1969 2B build Norwood RS/Z and trying to confirm the correct rear cover brake hose clip and fastener. There is a CRG thread on a related topic but it doesn' specifically address the clip ( http://www.camaros.org/forum/index.php?topic=3123.msg20270#msg20270 ). After researching the Rear Axle Brake Line Clip PN 3956700 I can't locate a photo of a similar one to compare with and the typical (HBC) repop is different and doesn't spec a bolt or washer. I'm confident that neither the diff or rear brake line have previously been out of the car or worked on as the car was sidelined in the 70's with just 22K miles and has the tell-tale signs of not being messed with including the original single-crimp rear brake line etc. My brake line clip uses a non-captured washer and non-shouldered bolt (see photos). It also has the presence of blue dye typical of frame located brake line clamps. I would appreciate opinions on originality
Brake Clip prior to diff removal and disassembly
by
Presence of blue dye on clip (similar to brake line clips used on the frame rails), large washer and non-shouldered bolt
HBC Repop Clip
Original Single Crimp Brake Hose
Re: Rear Axle Brake Line Clip PN# 3956700
« Reply #1 on: June 03, 2018, 09:15:14 PM »
Here is a sample I can offer;
1969 04C Z11 LOS Car
Edit deleted repeat wording & corrected year type-o (JFW 6/3/18)
Edgemontvillage
« Reply #2 on: June 04, 2018, 05:18:26 AM »
Thanks Jim, entirely different design that my example. Seems there is an air gap between the line and the clip, almost resembles a front brake hose clip.
HawkX66
« Reply #3 on: June 04, 2018, 12:00:55 PM »
Here is my original Lloyd. Sorry for the poor picture details. ~46 years of New England road grime. If I can remember before I move, I'll try to climb under there and get a pic of it now after I restored it.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
Edgemontvillage
« Reply #4 on: June 04, 2018, 02:07:08 PM »
Thanks Dave, would appreciate a post-restoration "after" photo if you have the time and opportunity. From what I can see, the same (as 11) shouldered bold is used and the clip appears to be similar to the HBC repop with flared/eased edges.
luv2sixty9
« Reply #5 on: June 04, 2018, 02:45:57 PM »
Lloyd,
Your clip I have seen before on a couple of Camaros, but its not the normal clip used. The Heartbeat City clip is the correct style. Dave
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
Edgemontvillage
« Reply #6 on: June 05, 2018, 01:19:23 PM »
Lloyd,
Dave, thanks for your input. Its becoming clear the clip is not typical however I'd sure like to see photos of other diffs of the period that used it.
x66 714
« Reply #7 on: June 05, 2018, 05:37:27 PM »
I'm trying to contact a friend that has a 01B car. Mine should match Hawks but I will check today or tomorrow. My 68 should look like yours but I will check that also. Both of my cars have stock exhaust so seeing them might be difficult.
Isn't JohnZ car from that date? Who has it now?....Joe
Edgemontvillage
« Reply #8 on: June 05, 2018, 08:31:26 PM »
Joe, I believe JohnZ's car is a 2D build date however would certainly like to know which brake clip was installed.
x66 714
« Reply #9 on: June 05, 2018, 08:46:30 PM »
http://www.camaros.org/forum/index.php?topic=14666.0
This is a car Steve Shauger either has or had. It's an 02b car....Joe
Edgemontvillage
« Reply #10 on: June 05, 2018, 09:51:49 PM »
I reviewed the linked thread however wasn't able to locate any photos of the brake line clip - where is it shown?
x66 714
« Reply #11 on: June 05, 2018, 10:00:11 PM »
It's not. I was just thinking you could contact him....Joe
HOT3O2
« Reply #12 on: June 05, 2018, 11:16:12 PM »
Lloyd,  This is the retainer / clip from my 12B VN Car.
Rick
69 RS/Z28
BillOhio
    • photobucket
« Reply #13 on: June 06, 2018, 01:19:58 AM »
This is on my 03D. I dont remember changing it
1968 RS 327 4 speed
Edgemontvillage
« Reply #14 on: June 06, 2018, 01:50:50 PM »
Rick, thanks for posting, it appears very similar to mine, I'm beginning to believe these were frame mount brakeline clips that were used - on occasion.
