Welcome to the CRG Discussion Forum!Classified ads are not allowed on the forum.
I think another key point is many cars can use the original hood hinge springs as in many cases they are not pitted with rust. A good soaking in Evapo-rust and oiling or some other rust preventative is all that is needed in many cases. Our 68 utilizes the original springs and they look like new.
Mike,(Don't want to steal this thread) Are those new GM springs in a zinc phosphate (silver), or in the manganese phosphate (dark gray)?
GM Part number?
Quote from: 169INDY on September 06, 2018, 02:33:40 PMGM Part number?The GM P/N is 3848372
Quote from: 169INDY on September 06, 2018, 02:33:40 PMGM Part number?The GM P/N is 3848372 and I paid $30 for the pair. It is a 28 coil spring. Attached is a picture of the spring in its packaged oil finish. It matches the hinge but in the photo it appears slightly darker. Mike
Scott, What are you talking about? The picture speaks for itself in regards to hue between the spring and hinge. Looking at it in person they look the same. The photo shows a slight variance. Mike
So what's this washer trick for spring replacement?
Quote from: Mike S on September 06, 2018, 05:19:11 PMQuote from: 169INDY on September 06, 2018, 02:33:40 PMGM Part number?The GM P/N is 3848372 and I paid $30 for the pair. It is a 28 coil spring.It doesn't look like that part number is good anymore. I did find #3848272 which is also a 28 coil spring for $14.62 each. I hope it's the same one. There are also some springs listed on ebabe with the same 3848272 part # which allegedly also fit Impala, Camaro, Chevelle and Firebird. BL
