Author Topic: XXB suffix code  (Read 9349 times)
Re: XXB suffix code
« Reply #15 on: May 28, 2018, 07:00:53 am »
My suspicion is that it was not used for the 350.
In 1967, the 327 and 350 had different part numbers - both for short block engine assemblies and “fitted blocks”.  A fitted block in generally a short block - minus the rods and crankshaft.
The CE coding did not start until September of 1967. Prior to that, only complete engine assemblies revived a stamped code on the pad. Short blocks prior to September 1967 had blank pads.
Now you have me curious and probably won’t sleep much until I find an answer.  :)
« Last Edit: May 28, 2018, 07:28:16 am by bcmiller »
Re: XXB suffix code
« Reply #16 on: May 28, 2018, 07:33:19 am »
My suspicion is that if the engine in a 1967 Camaro SS 350 had a warranty issue prior to September 1967, it received an unstamped large journal short block. Remember in the 1967 model year, the 350 was only available in the Camaro.
