Author Topic: Carb for 327 300 horsepower  (Read 7379 times)
dalekerr
« on: May 08, 2018, 06:45:00 PM »
Just  had delivered last night a 1967 Camaro 327 slighlty  modified with headers, muncie 4 speed,  DUI distrubter and Double hump heads.
The carb is bad keeps leaking down after sitting a whie roch Q jet.
Suggestions for a new carb i am leaning to a edelbrock 500?
Want reliabilty and mild performance.  Going to drive this one often.
Dale Kerr
1967 Y 2 350 M20 12 Bolt Vintage Air
03D
Stingr69
Re: Carb for 327 300 horsepower
« Reply #1 on: May 09, 2018, 11:00:48 AM »
You should fix the Qjet setup you have now.  It is the best carb for your application.  Might be cooking the gas out after you shut down. There are fixes for that.
Kelley W King
« Reply #2 on: May 09, 2018, 12:33:14 PM »
If the Qjet is not matching or anything special the chain stores sell rebuilt units fairly cheap. I agree on it being best for your application. Check your numbers before using yours as a core.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
joesauer
« Reply #3 on: May 09, 2018, 08:15:21 PM »
If you prefer a new carb vs rebuild or chain store version, suggest an Edelbrock 600 cfm with electric choke (reliable & simple to adjust).
dalekerr
« Reply #4 on: May 09, 2018, 09:16:49 PM »
Thanks for the replies, I ordred an Edelbrock 1403 500CFM yesterday and will install it next week, no driving the car till then. After installing the new carb, I will have to change the oil you can smell the gas in it.
My last Camaro was an numbers matching 68 RS SS 350 with a rochester carb it did the same thing when it was first purchased after been sitting for years.
The 67 i just purchased had been sitting for a while, this must be an issue with the rochester carb.  Owner died. Widow sold car to me.
Dale Kerr
03D
Kelley W King
« Reply #5 on: May 10, 2018, 01:02:52 AM »
Some times a carb sitting for years wil dry up and the gaskets shrink. You might want to try it after the gaskets swell. My gto has done that and a day later no leaks.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
