Author Topic: Engine mod - thoughts?  (Read 13223 times)
Re: Engine mod - thoughts?
« Reply #15 on: April 25, 2018, 09:55:55 PM »
Yeh I am an old circled tracker, from a young age worked on those cars. Didn’t get to drive as much as I wanted to though.
camaroboy68ss
  • 1968 L30/M20
« Reply #16 on: April 26, 2018, 07:34:34 PM »
The 186 and 462 heads are relatively easy to find.  Most are of the 1.94 variant which isn't a big deal.   I never run a set of old heads without completely going through them, and for me that means new valves, seats and guides, positive seals etc...  While doing that it's not a big deal to upgrade to the 2.02/1.60 valve arrangement.   As far as I'm concerned, I'm paying for all this stuff either way so it's a no brainer.
  So don't pass up a set of heads just because they're 1.94's, chances are they'll be priced cheaper anyway, and smart money says you'll be sending them to a shop for a rebuild so.....
I used to always have same thing done with old heads, something i learned from my grandfather growing up. Until going to a new machinist for a set of heads and showed why just swapping  2.02s into a 1.94 head does get the results you are hoping for. He had 2 cut up heads from blown motors that junked the head and the ports are different in shape depending on the factory valve. To get the most out of the swap you need to do some port work to get the correct factory 2.02 performance than just slapping valves in.
Young gun with a Camaro or 2.
1968 Camaro RS L30/M20, 2017 Camaro SS
1968 Chevy C10 - Twin to the Camaro
1933 Ford Pickup - "Camaro in disguise"
X33RS
« Reply #17 on: April 26, 2018, 10:08:27 PM »
I didn't bother to mention this because most any machinists you go to does it, but it's pretty common while cutting for the larger seats they'll run the bowl tool down and enlarge the throat a small degree.  That's probably what you are seeing on a factory 2.02 head.
What head porters like about this method (installing larger valves in a smaller valve head) is that they can manipulate the bowl to their liking for best flow results as they have more to work with, rather than having a larger throat with less material to start with.  So there is an advantage to this process.
As far as intake and exhaust runner size, as well as combustion chamber, there is no difference.  I've CC's original 2.02 heads and 1.94's that I have here.  Nothing about them changed in that regard.
« Reply #18 on: April 26, 2018, 11:44:07 PM »
Not directly related to the post, but have you ever checked any 487X heads? :)
« Reply #19 on: April 27, 2018, 12:12:37 AM »
file this under "I need a boot upside the head" regret file. Way back, a guy GAVE me a set of 461X heads. The rocker stud bosses were cracked, so I pitched them in a dumpster.
Back to the OP - How 'bout a virgin set of 492 2.02s?
X33RS
« Reply #20 on: April 27, 2018, 03:49:44 AM »
I have 2, maybe 3 sets of "X" heads here and I believe one of them are 487's.  I'll dig through the stash this weekend and see.   What would you like checked on them?
I know one "X" set I have are from my 1970 400 SBC and are casting 441X.   1.94 intake but came factory with a  1.6 exhaust valve.  1970 400 was the only year and engine app they did that.
I should have said above that when there was no difference in the 1.94 and 2.02 heads as far as chamber and runner CC's, I was referring to the hump heads, specifically the 461's (no accessory holes)  and 186's (accessory holes) I have here.
« Reply #21 on: April 27, 2018, 04:33:11 AM »
Yep.
487X should CC more than double humps. I have several sets stashed from years ago.
Stingr69
« Reply #22 on: April 27, 2018, 12:35:14 PM »
Did you see the extra machining operation in the chamber?  The chamber wall casting is cut wider on the intake side for factory big valve heads.
67jeffreyt
« Reply #23 on: June 27, 2018, 12:41:12 AM »
My 67 Camaro got the treatment too but I went too big on cam basically duntov 30-30 specs for hydraulic roller. I have 67 heads with 2.02 valves, double roller springs, stock quadrajet intake and carb, I'm at 10-1 and my car is not running with any power, ive read that the carb needs changed to match the cam
67 ss/rs camaro currently
68 prostreet Camaro 9.60 1/4 mile
68 Rallysport, first car high school
89 rs camaro convertible, made readers rides super Chevy
67jeffreyt
« Reply #24 on: June 27, 2018, 12:49:34 AM »
My head's were rebuilt with 2.02 stainless valves, I cut the valve spring seats and fitted the heads for double valve springs, and stainless rockers
Kelley W King
« Reply #25 on: June 27, 2018, 09:22:45 PM »
What gear you running? A set up like yours with 3.08,s might not feel too peppy. More flow does not help until you get some RPM.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
67jeffreyt
« Reply #26 on: July 14, 2018, 04:01:48 PM »
My gears are factory 3.31 12 bolt posi rear, car picks up at 3,500.  Just changed out the factory 67 dual plane intake for a 1974 Edelbrock Street master single plane, to keep the look of the 67
67jeffreyt
« Reply #27 on: July 14, 2018, 04:05:48 PM »
This engine back together, not too bad
