Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Orphans - documentation or VIN-stamped drivetrains - in search of the original cars
1968 - Orphans
8N337153 MQ 396 block (hurt)
« previous
next »
Print
Pages: [
1
Author
Topic: 8N337153 MQ 396 block (hurt) (Read 5683 times)
Hero Member
someday I'll get one finished
on:
March 28, 2018, 03:38:58 AM »
1968 Camaro Big Block Chevy BBC 396 375hp MQ 4 Bolt Block 3916323 323 J-12-7
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F332581306854
Tweet
Logged
Hero Member
Re: 8N337153 MQ 396 block (hurt)
Reply #1 on:
March 29, 2018, 05:34:21 PM »
That's a $500/210lb protect-o-plate..
Logged
CRG Member
Reply #2 on:
March 29, 2018, 06:50:27 PM »
I tend to agree. I am not sure I would want to deal with having that fixed. Unless I owned the car...
Logged
Bryon
/ 1968 Camaro SS 396 coupe - now old school 468 big block
169INDY
Hero Member
Reply #3 on:
March 29, 2018, 07:16:13 PM »
If I had the Car, build a CE L78 Motor and then take this Cylinder-Block and manufacture a glass topped coffee table ,,,,,
I concur it is almost only worth something to the owner of that VIN,
Logged
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
Hero Member
Reply #4 on:
March 29, 2018, 07:33:59 PM »
I'm curious what cased the block ends to break off.
Never had seen that before even on abused motors.
Logged
Kelley W King
Hero Member
Reply #5 on:
March 29, 2018, 08:31:47 PM »
I have seen it before. Clutch exploded. That what scattershields are for. Car might be easy to find. Holes or big dents in the floor.
Logged
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
CRG Member
Reply #6 on:
April 02, 2018, 02:38:14 PM »
I think you are right. It was some type of clutch/pressure plate/flywheel failure that caused the damage. And people need to remember to also run the block plate when the run a scatter shield. It's good insurance.
Logged
Bryon
CRG Coordinator
Reply #7 on:
April 02, 2018, 06:06:37 PM »
I wouldn't be afraid of that block. Sleeves are a fine option. If I had a 8N337xxx and was NOM, I'd run that......
Logged
CRG Member
Reply #8 on:
April 02, 2018, 06:36:42 PM »
Sleeves usually are not a problem.
The areas in the rear where it was damaged and repaired (both sides) are what I would be worried about.
Logged
Bryon
70L34
Member
Reply #9 on:
June 09, 2018, 09:39:39 PM »
Looks saveable if you wanted to save it.
Logged
Hero Member
Reply #10 on:
June 09, 2018, 11:30:21 PM »
Looks like it was welded with a nickle rod. I don't like the porosity, it could leak oil under pressure.
Logged
Doug '67 RS/SS 396 auto I know the car since new
Print
Pages: [
1
« previous
next »
1968 - Orphans
