Author Topic: Adding a non-gauge console?  (Read 18359 times)
Re: Adding a non-gauge console?
« Reply #30 on: March 27, 2018, 07:38:42 PM »
I think most are a rough cut like that. Surprising they didn't have a template, jig, or something to make it clean and uniform. Seems like it would have taken more time with the ragged cut.
« Reply #31 on: March 27, 2018, 08:03:51 PM »
 My 67 has a nice stamped opening with a reinforced band spot welded around it for the shifter boot to screw into.
I guess it was cheaper to rough cut it afterwards. I'm surprised GM just didn't punch the opening and leave off the spot welded band.
bheston
« Reply #32 on: March 27, 2018, 08:34:18 PM »
No, they were not a split nut. They're called a "rivnut."
My factory one:
You wouldn't happen to have a picture of the other side to show the crimp?  :)
HawkX66
« Reply #33 on: March 27, 2018, 08:45:47 PM »
My factory one:
I do, but I'll have to look for it.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
« Reply #34 on: March 28, 2018, 02:34:19 AM »
Dave,
  Is that rough cut factory?
The 4 speed hole? Yes, that's factory cut.
That's a rough one - must have been a Monday after a long weekend, or a Friday in anticipation of a long weekend. I know they were torch cuts, had to have a pattern to trace the outline of the boot retainer (or maybe used the boot retainer as the pattern ?).
bheston
« Reply #35 on: March 29, 2018, 10:52:05 AM »
I haven't ripped-up the carpet to look, but is it safe to assume that there are dimples in the locations for the front console bracket even for non-console cars?
Kelley W King
« Reply #36 on: March 29, 2018, 12:49:03 PM »
If that is from the AIM evidently the line did not see that picture of the cut out. Were the standard 3 speeds cut like that also?
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #37 on: March 30, 2018, 01:45:10 AM »
Absolutely. I believe the dimples are in place for the Rivnuts as well - I'll look on my tunnel section I have in storage (non-console) for the rears, but I know beyond doubt the bracket dimples are there, Camaro or 'Bird either way. Had to save a bunch of time on the line to pop the holes in the dimple locations (same for firewall dimples).
« Reply #38 on: April 02, 2018, 09:11:58 PM »
JohnZ says that the torch cut was so they didn't have to have another stamping for the floor. Three stampings were enough - the 3-speed and the auto and the column shift.
« Reply #39 on: April 02, 2018, 09:56:04 PM »
 I would think the 3-speed (and 4 speed) and auto would be the same hole dimensions.
At least in 67 they look the same.
x66 714
« Reply #40 on: April 03, 2018, 01:09:53 AM »
The floor shift automatic in 68 and 69 had no hole for the shifter body itself. It was a plate mounted to the top of the floor...Joe
« Reply #41 on: April 03, 2018, 03:42:58 AM »
Correct. One smaller hole for the shift cable through the floor, behind and above the shift lever on the side of the trans.
bheston
« Reply #42 on: April 04, 2018, 10:39:57 AM »
Still formulating my install plan.  The non-gauge console wiring harness generally is supplied with the repro consoles.  However, where is the wiring harness on the car side?  That is, I presume that a non-console car does not have the #1 harness shown in the AIM?  :-\  Below is a clip from the AIM.  Does anyone have pictures or routing of the harness?
