1969 rear leaf spring cup front eye bolt & nut part#3892754 & 9417614
Danzo:
Is tis the correct finish for this bolt and nut? Thanks.
http://www.heartbeatcitycamaro.com/store/product/19652/68-69-70-71-72-73-74-Camaro-%26-Firebird-Rear-Leaf-Spring-Cup-Front-Eye-Bolt-With-Hardware-Sold-As-each/
luv2sixty9:
No, its also the incorrect head marking.
Danzo:
Thanks for the reply. What would the correct finish and head marking be?
Thanks.
WorkinProgress:
The nut is the correct finish.
- Warren
z28z11:
Here's an original - as far as I can tell, it was a phosphate finish (no evidence of cad or zinc iridite), either plain steel or phosphated nut and washers. Bolt is 1/2-20, 4-13/16 length under the head. Only marking I can see (sorry for the rough finish) after beading is an "L", which I highlighted best I could for the pic. I have both sides, they are identical markings and specs.
Hope this helps -
Navigation
[0] Message Index
[#] Next page
