Author Topic: 1969 rear leaf spring cup front eye bolt & nut part#3892754 & 9417614  (Read 7225 times)
luv2sixty9
Re: 1969 rear leaf spring cup front eye bolt & nut part#3892754 & 9417614
« Reply #1 on: February 24, 2018, 03:08:38 PM »
No, its also the incorrect head marking.
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
Danzo
« Reply #2 on: February 24, 2018, 06:58:49 PM »
Thanks for the reply. What would the correct finish and head marking be?
Thanks.
WorkinProgress
« Reply #3 on: February 24, 2018, 07:48:07 PM »
The nut is the correct finish.
                - Warren
« Reply #4 on: February 25, 2018, 04:02:36 AM »
Here's an original - as far as I can tell, it was a phosphate finish (no evidence of cad or zinc iridite), either plain steel or phosphated nut and washers. Bolt is 1/2-20, 4-13/16 length under the head. Only marking I can see (sorry for the rough finish) after beading is an "L", which I highlighted best I could for the pic. I have both sides, they are identical markings and specs.
Hope this helps -
Edgemontvillage
« Reply #5 on: October 09, 2019, 02:33:18 AM »
After reviewing this thread a conclusion would be the spring cup eye bolt, washers (2) and nut were all originally manganese phosphated for '69. I'd be interested in any other observations as only one CRG member provided a photo. The restoration parts suppliers sell this fastener in gold iridite or zinc.
« Last Edit: October 09, 2019, 02:58:22 AM by Edgemontvillage »
« Reply #6 on: October 09, 2019, 03:45:25 AM »
1969 LOS 04C
Heavy undercoated the Nut appears brite Zinc under the nasty's.
« Reply #7 on: October 09, 2019, 12:05:35 PM »
I checked mine last night, appears to be phosphated originally...
Pacecar
« Reply #8 on: October 09, 2019, 02:39:34 PM »
Don't mean to hijack topic but what about the rear end U Bolt nuts ? The ones on the U bolts that mount the springs & shackles to the rear axle. What finish on those ?
« Reply #9 on: October 09, 2019, 06:01:11 PM »
Heavy-Duty Lock Nut, Grade C SAE (Fine) Thread - Nuts - Nuts - Fasteners & Hardware
Zinc plated, silver finish
Edgemontvillage
« Reply #10 on: October 17, 2019, 02:49:06 PM »
Thanks for posting photos and other references. Seems to be inconclusive regarding the finish on the nut - phosphate or zinc? Jim you stated: "Heavy-Duty Lock Nut, Grade C SAE (Fine) Thread - Nuts - Nuts - Fasteners & Hardware Zinc plated, silver finish", where did you source this information?
« Reply #11 on: October 17, 2019, 03:35:09 PM »
The bolt & nut might be a UNC course thread vice Fine thread.
Zinc plated is what I found on my particular car during underbody restoration.
The rest is typical fastener jargon.
Edgemontvillage
« Reply #12 on: October 18, 2019, 12:17:13 AM »
Thanks Jim, on re-read I now realize you were commenting on the finishes for the axle U bolts and nuts.
Edgemontvillage
« Reply #13 on: October 21, 2019, 01:11:46 AM »
I just came across a photo of my former '69 10 10 RS/Z survivor that was taken by James G (firstgenaddict) about the time the car was found following almost 2 decades of storage. The photo could be clearer and the lighting is not great but it does appear the eye bolt's nut and washers were zinc plated. Another clue is the full surface rust present on the surrounding fasteners that are known to be phosphated
Edgemontvillage
« Reply #14 on: October 21, 2019, 01:21:46 AM »
Another angle:
