Author Topic: Reverse Lockout  (Read 1575 times)
jim28607
Reverse Lockout
« on: September 06, 2017, 10:33:39 PM »
Hello All !!
I am interested in installing the reverse
lockout linkage on my 69 BB RS/SS 4 spd ,
It seems there are a few variations of this and
I am not sure which version belongs in my car ,
I do know that there are 3 holes in the frame
at the mounting location
But only two of the holes are threaded .
Any help or direction is greatly appreciated !
Re: Reverse Lockout
« Reply #1 on: September 07, 2017, 03:11:52 AM »
Finding the parts seems to be the biggest problem today, as so many of them got 'tossed' when headers were installed...
jim28607
Re: Reverse Lockout
« Reply #2 on: September 07, 2017, 11:04:39 AM »
I have found a 3 tab mounting and
a 2 tab mounting , just not sure which is correct ?
ZLP955
Re: Reverse Lockout
« Reply #3 on: September 07, 2017, 11:16:37 AM »
Jim, there used to be a great tech article in PDF format here: http://www.worldwidecamaroclub.com/forum/tech-articles/1st-gen/1560-1969-reverse-lockouts
which provided reference pictures and a list of part numbers for the subframe pivot/swivel mechanism and upper/lower linkage rods, for each engine/trans application. It doesn't seem to be available anymore, but I'm pretty sure I saved a copy somewhere. It's probably on an old computer, but I'll try and find it.
Tim in Australia.
1969 04A Van Nuys Z/28. Cortez Silver, Dark Blue interior, VE3 bumper, Z21, Z23, D55/U17, D80, flat hood.
Sold at Clippinger Chevrolet in Covina, CA. Ex-E/MP at Lions Dragstrip in Long Beach.
Re: Reverse Lockout
« Reply #4 on: September 07, 2017, 12:40:09 PM »
Lock-out parts are different between automatics & 4-speed.
Only Muncies used the two-tab swivel mount & upper lock rod 3945599. Small-blocks use lower lock rod 3955773; big-blocks 3955776. Saginaw 4-speed parts are not the same.
The '69 Camaro Assembly Instruction Manual is a great reference.
dale_z28
Re: Reverse Lockout
« Reply #5 on: September 07, 2017, 04:56:41 PM »
Someone from the group provided this picture when I had a question; hope it helps (and I still haven't purchased mine, but Heartbeat City lists one)
'69 X33 02D   Since 11-29-'77
~Ben Franklin
jim28607
Re: Reverse Lockout
« Reply #6 on: September 07, 2017, 10:05:53 PM »
This is great information,
Thanks for the help and keep it coming
More pics too please !!
Best to all,
jim28607
Re: Reverse Lockout
« Reply #7 on: September 10, 2017, 12:35:54 PM »
Thanks, so is it safe to say
that since my frame has only
two of the theee holes threaded , that the car was a factory muncie car?
Re: Reverse Lockout
« Reply #8 on: September 10, 2017, 07:21:01 PM »
Tha
That, or a fastener was left off at assembly ( which is very possible)? The subframe could have been replaced? So, an assumption can be made , but not a factual assertion. You would want to look for the hole in the firewall as a better clue of your car being muncie equipped.
James to strangers, Bentley to friends
1969 SS/RS 396 coupe Hugger Orange X22 712 bought in 79
1969 SS 350 coupe LeMans Blue 713 bought in 79(sold)
1969 307 4spd. coupe Daytona Yellow 711 bought in 85
Re: Reverse Lockout
« Reply #9 on: September 10, 2017, 09:45:41 PM »
That and the Muncie-only speedo cable routing.
Kelley W King
Re: Reverse Lockout
« Reply #10 on: September 11, 2017, 09:15:35 PM »
Now if we only had a header brand and part number that does not interfere with the linkage you would be all set.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
