Author Topic: 68 z28 correct throttle rod  (Read 8124 times)
Tx-Z 302
« on: August 04, 2017, 01:50:32 AM »
Whats the difference in a z28 2 piece throttle rod and the big block 2 piece rod?
Chris W
WorkinProgress
Re: 68 z28 correct throttle rod
« Reply #1 on: August 04, 2017, 06:58:31 AM »
The rod that attaches to the carb has a different bend. The back half of rod or the part the front rod threads into is the same for small block and big block.
        - Warren
Tx-Z 302
« Reply #2 on: August 04, 2017, 05:44:08 PM »
Thx Warren
Chris W
Tx-Z 302
« Reply #3 on: August 04, 2017, 10:42:10 PM »
If anyone has pics of each rod that would be stupendous.  Are they interchangeable or no?
Chris W
« Reply #4 on: August 05, 2017, 12:40:23 AM »
Google is your friend.
« Last Edit: August 07, 2017, 07:44:23 PM by bertfam »
« Reply #5 on: August 05, 2017, 03:11:12 AM »
 The L34 /L35 rod shown above is for use with the earlier Quadrajets that used a rubber bushing w/plastic insert in the throttle arm. The L78 style was used on the later '67 L35's that used a Quadrajet but the throttle arm no longer used the rubber bushing. Both my L35's w/Q-jets (March/April 67) use the L78 style rod.
rare396bronze
« Reply #6 on: August 06, 2017, 04:10:34 AM »
My 68 396/325 use's has L78 rod. Did some research 68 & 69 assembly manual show's the same rod for 325 & 350 HP as 375 HP. Also my 69 gm parts book give the same part's for all 68-69 396. Always trust my part's books over google. But found out 67 z-28 front rod uses different # than 68-69 z28 would like to know what was the difference.
« Reply #7 on: August 06, 2017, 02:11:41 PM »
Sport, A clue to look at is the difference in Assembly manual between the 2.  67 UPC Z28 Sheet A3 & 68 UPC Z28 Sheet A3.  Throttle arm linkage changed on the 3910 to the 4053. Ill have to look at my photos as I dont fully agree with the pic above on throttle rod applications.
Tx-Z 302
« Reply #8 on: August 06, 2017, 02:21:04 PM »
I'm in the market for a 68 z original.  :)
Chris W
rare396bronze
« Reply #9 on: August 06, 2017, 04:28:08 PM »
Try Jerry MacNeish or Camaro Specialty's in New York!
« Reply #10 on: August 07, 2017, 07:14:04 PM »
How's the picture look now boys?
rare396bronze
« Reply #11 on: August 08, 2017, 02:44:33 AM »
Perfect!
« Reply #12 on: August 09, 2017, 12:19:18 AM »
Well if you want to be 100% correct...  67 Z shows a different part number for the front half of the throttle arm linkage vs 68 & 9 in the AIM.  The rear portion is all the same for all 3 years.  67 used a cotter pin and the 8&9 used e clips to attach to the throttle arm of the carb.
169INDY
« Reply #13 on: August 27, 2021, 03:08:38 PM »
I was curious about the apparent throttle arm rod  front and rear portions component finishes as related to the photo from: July 1968 Car Life Road test Page 47
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
dannystarr
« Reply #14 on: August 27, 2021, 04:41:06 PM »
This is off one of my survivor cars. Carb rebuilt but Engine never out. Cowl Tag Date O5C. Hope this helps. ... Danny
 What happened to the pictures being cut off?  Maybe someone can fix it?
