Author Topic: 68 Big Block Radiator Codes  (Read 3102 times)
rod396
« on: June 26, 2017, 02:55:11 PM »
I am of the understanding that the 67-68 Big Block radiator code on the pass side tank for manual trans is "OL", and this is for a 4-row core (?) but I can't seem to find what the code would be for a 23-inch, 3-Row core, Big Block, manual trans.
Does anybody know what the correct code for the pass tank would be? Original/survivor examples.
Thank you.
Re: 68 Big Block Radiator Codes
« Reply #1 on: June 26, 2017, 02:59:51 PM »
Have you looked at the tables here at this link below?
http://www.camaros.org/coolingsystems.shtml
« Reply #2 on: June 27, 2017, 01:44:51 AM »
Has a 4 core ever been documented in a 68 manual trans? According to the highlighted data and my own knowledge, I haven't seen one.
rare396bronze
« Reply #3 on: June 27, 2017, 02:42:07 AM »
Yep 396 with a/c. My 68 with 4 speed has the 4 core.
« Reply #4 on: June 30, 2017, 03:34:47 AM »
I am of the understanding that the 67-68 Big Block radiator code on the pass side tank for manual trans is "OL", and this is for a 4-row core (?)....
That's not what the radiator tank table in my article  shows. It  says big block and does not differentiate between the different cores.
rod396
« Reply #5 on: June 30, 2017, 08:23:31 PM »
So it is only the tag that is affixed to the tank that specifies the core
The OL only denotes the larger tank itself
