Author Topic: Non reveal felts  (Read 2491 times)
Non reveal felts
« on: June 16, 2017, 08:14:59 AM »
Does anyone know the size and type screw to hold the felts on the doors?  I got the new ones in with the clips and when I took the old one off there were some screws at either end under the belt, (I had the reveal belts on and took them off) but I want to make sure before I re-use what was there.  It would seem you need a small flat head to go deep into the felt to not scratch the glass.
On another note.  I have some screws holding my door rubber seal at the front.  The rear has some plastic push clips holding them to the door, but the front had screws.  Did the front use the plastic as well?  If so, does anyone know where to get them?
A pic of the screws in front.  Very bottom of page.
http://www.camaros.org/forum/index.php?topic=5380.msg35236#msg35236
jeff68
Re: Non reveal felts
« Reply #1 on: June 16, 2017, 11:14:33 AM »
My door weatherstripping used plastic retainers front & back.  The retainers are available from HBC under p/n WTS-1027.
« Reply #2 on: June 16, 2017, 03:49:26 PM »
Thanks Jeff.
