Author Topic: Ride Height Measurements  (Read 13810 times)
enio45
« on: November 22, 2005, 02:45:55 PM »
I could some help on this topic....im researching some double park lift products and i need to know the height of the car.....does anyone have the official measurements from GM ( usually in the owners manual) of
1.  floor to roof height
2.  floor to  mid front fender
3.  floor to mid trunk
Assumption all stock components, tires and wheels
I need this for 68Z and 69Z
Thanks for your time
Eddie  Montini
Re: Ride Height Measurements
« Reply #1 on: November 22, 2005, 03:04:33 PM »
The only AMA-published height dimensions are ground-to-top of roof, which is 51.1", and ground-to-top of cowl, which is 36.4"; those dimensions are for 69's.
enio45
« Reply #2 on: November 22, 2005, 04:25:39 PM »
Thanks John...anyone for the 68 measurements?
Eddie  Montini
mr396
    • 1968 camaro SS 396 RS convertible
« Reply #3 on: November 27, 2005, 02:59:48 AM »
this is the AMA spec sheet for 1968, hope it helps.
1968 camaro RS/SS L34 396 air convertible
enio45
« Reply #4 on: November 30, 2005, 11:14:41 AM »
Yes, thank you very much!! ;)
Eddie  Montini
deejaygee
« Reply #5 on: November 30, 2005, 08:16:38 PM »
Wouldn't you need to add an extra inch for the Z28 to account for the 15" wheels?
« Reply #6 on: December 01, 2005, 04:02:11 PM »
Nope - the Z/28 design ride height (a function of spring height at design load) was lower than any other Camaro model.
oscar
« Reply #7 on: April 04, 2006, 10:50:28 PM »
Hi Enio. Do you know the factory ride height of a z-28 1969 camaro. In particular the ground to bumper height and /or the lip of fender to mid hub. Many thanks.
Oscar
« Reply #8 on: April 05, 2006, 04:15:22 PM »
'69 ride heights are specified in terms of design front and rear suspension heights (spring deflection) and rocker-to-ground heights; there's a chart in the UPC 0 section (sheet A10) of the '69 Assembly Manual that shows how to measure them and gives the numbers for each tire size/option condition.
oscar
« Reply #9 on: April 05, 2006, 10:41:09 PM »
many thanks!
Adz28
« Reply #10 on: January 17, 2008, 09:12:30 PM »
Hi John,
Regarding UPC 0 / A10 in the Assembly Manual...
Do you know if the measurement is taken from the ground to the flat finished part of the rocker panel, or to the "unfinished" flange that hangs a bit lower?
Thanks.
« Reply #11 on: January 18, 2008, 08:09:53 PM »
Hi John,
Thanks.
It's taken to the flat finished lower surface, not to the bottom edge of the weld flange.
