Author Topic: 1969 Z28 jack  (Read 4934 times)
cbgolz
1969 Z28 jack
« on: June 01, 2017, 11:23:08 PM »
Was the 1969 Z28 jack ratchet assembly tower originally silver or anodized gold?  I have seen them both ways.  Which is correct, or are both correct depending upon production plant, date, etc.?  Is there a particular paint I should use to replicate either or both of these colors?  Thanks for your help.
Re: 1969 Z28 jack
« Reply #1 on: June 02, 2017, 12:48:34 AM »
Is your car NOR- or LOS-assembled?
cbgolz
Re: 1969 Z28 jack
« Reply #2 on: June 02, 2017, 04:57:18 AM »
My car is a NOR X77 car.  Thanks.
Re: 1969 Z28 jack
« Reply #3 on: June 02, 2017, 06:58:46 AM »
Jerry MacNeish's book lists the jack mast as 'gold or silver cadium dichromate' but I'm not sure if there is a timeframe or assembly plant that could indicate one or the other as more likely for your car (as you're obviously already thinking).
Personally, I would go with replating the mast, paint will just not look correct IMO.
Hopefully someone with an original NOR car (mid-production or later, since yours has an X-code) can confirm if theirs is gold or silver.
Re: 1969 Z28 jack
« Reply #4 on: June 02, 2017, 07:14:01 AM »
I have a 08C (august of 69)norwood car, and the mast is gold-ish, with the jack mechanism grey.
sorry i do not have a great pic of it.
hope this helps  :)
Re: 1969 Z28 jack
« Reply #5 on: June 02, 2017, 05:35:41 PM »
I believe there was more than one supplier. I have seen both finishes. And to my knowledge there is nothing specific about the jack in a Z28.
cbgolz
Re: 1969 Z28 jack
« Reply #6 on: June 03, 2017, 03:31:02 PM »
Thank you all very much for your help.  I will proceed.  CDG
