Author Topic: 68Z vacuum advance?  (Read 4385 times)
Tx-Z 302
68Z vacuum advance?
« on: April 02, 2017, 10:29:43 PM »
my 467 distributor has been refurbished, it had a 452-10 advance on it, but there is a 400-15 in the misc. parts that came with car, ive been reading everything but not sure which is correct or why the 452-10 was put on if the 400-15 is supposed to be?
Chris W
Re: 68Z vacuum advance?
« Reply #1 on: April 03, 2017, 02:41:25 AM »
It should have the 400 unit. 15 degrees of advance.
Tx-Z 302
« Reply #2 on: April 03, 2017, 12:54:01 PM »
Thank you kurt. Is there a way to check if the 400 is working properly? If it isn't is there anyone that can rebuild mine or is it junk at that point?
Chris W
« Reply #3 on: April 03, 2017, 02:35:03 PM »
Find someone with a distributor machine like a Sun machine. Install everything and run it up with vacuum applied and see if it  gives 15 degrees.
Z28Project
« Reply #4 on: April 03, 2017, 05:04:48 PM »
Or at the very least, just apply suction to it and confirm that the rod pulls in and holds until suction is released.  That will let you determine if it is functioning or not.
John
69 Z/28 NOR 12B X33 H.O. 'Ex-Racer'
Tx-Z 302
« Reply #5 on: April 04, 2017, 12:42:30 AM »
Thx
Chris W
