Have my x44 diassembled(mostly).. needs all 4 floor corners, driver toe board and hump repair( cut for floor shifter)also both rear quarters and outers wells(but only rusted around the wheel openings).. tail pan rusted and roof had something fall on it and poorly repaired... front frame is still connected and all 4 bolts have come loose.. Going to be a driver..
I read that i should have the front frame connected and rear suspension in place to replace the rear quarters so the weight distibution will be the same after its complete. also is it better to just replace the floor with a one piece or do each seperate.should i do the floor first or the quarters? it would also seem better to replace the roof last but not sure...? all opinions appreciated..!!!
