1111467 distributor - mucho money
(1/1)
z28z11:
For anyone that needs one and has the dollars - from my home state, sorry to say -
http://www.ebay.com/itm/1968-Z28-Camaro-302-290hp-engine-distributor-1111467-/122398613945?hash=item1c7f86a1b9:g:wngAAOSw5cNYhUfk&vxp=mtr
A little harsh, if you ask me. Good piece anyway, good date, legit.
jdv69z:
But free shippiing is included! ???
Is this what a 1111480 dist is going for as well?
BULLITT65:
As an observer I have seen (real) 1111480 go for $500 up to 1200. Haven't seen a pattern as far as when the dist was stamped, just some guys pay more than others. If I owned a 68 Z dist I would start high and see if someone made an offer, just because there are less of them out there. I assume it will sell in the sub 1000 range, because I think demand is much less for the 68Z
z28z11:
Add the 499 distributor in and you have the triumvirate of too-expensive-to-buy-if-you-don't-need-to Camaro distributors. Whovever has the 467 in the ad above is way over the top, maybe a speculator ?
I agree with the 480 pricing - I've seen the same. 499's usually go for 600-900; 467's seem to be higher likely due to the low production numbers of the '68 Z's in comparison to '69's, or 396/350 horse w/ air, L78's and others that require the 499.
Tx-Z 302:
My 467 has vac advance 400-15 does anybody know what the original production units are? I've seen a myriad of different numbers on here?
Navigation
[0] Message Index
