Bypass fitting 68Z
(1/1)
Tx-Z 302:
Ok so my fitting is hex rather than square. Is it supposed to be brass or steel ? Played or natural? And lastly mine is not perfectly 90 degrees it appears to be aimed slightly downward? Bent? Correct? OTC part ? No pic yet to post
The pump has just the small hole and the hub has a single set of holes rather than the eight hole set up?
68camaroz28:
Chris, here's an original that's in our 68Z. Some seem to have maybe a very slight angle but its not much and they are metal and painted as was the hose as well as they were on the engine assembly when painted at Flint.
Navigation
[0] Message Index
