Author Topic: Electronic Distributor  (Read 6600 times)
dab67
  • 67 SS
« on: January 17, 2007, 04:43:24 PM »
I am thinking about upgrading  my SBC  Distributor to Electronic. Any recommendations on what brand to buy? I want it to look as original as possible with a black cap etc.
dab67
wtexz10
Re: Electronic Distributor
« Reply #1 on: January 17, 2007, 05:49:37 PM »
I'm using a Pertronix module inside my original distributor.  It's been in their for 5 year with no problems.
Kris
69 Camaro Z10.. 72 GMC C1500
79 Mazda RX7.. 79 Trans Am WS6
06 Corvette Z06.. 10 BMW 650i
Adz28
« Reply #2 on: January 17, 2007, 06:02:37 PM »
I am also using the Pertronix (Ignitor II) in my original distributor, along with the Flame-Thrower Black coil. The paint on the coil is a bit shinier than the stock coil. The label can also be peeled off. Looks pretty close. I put it in about a year ago on the recommendation from someone else using the Pertronix in a similar set-up and it has been running great.
« Last Edit: January 17, 2007, 06:10:18 PM by Adz28 »
dab67
  • 67 SS
« Reply #3 on: January 17, 2007, 06:44:02 PM »
Kris and AD:
Thanks for the input I will check out the systems you two are using.
dab67
« Reply #4 on: January 17, 2007, 07:21:55 PM »
If you want to go completely stock looking (in other words, one wire going to the distributor instead of the Pertronix two), check out the BREAKERLESS STELTH system. I've not used it myself, but others have. No complaints so far (other than the price).
sebastien
« Reply #5 on: January 20, 2007, 12:58:51 AM »
Same here,I just put a breakerless stealth in my original distributor with the original coil.I recommend it to anyone.works great.
http://www.lectriclimited.com/breakerless_se.htm
Sebastien 68  327 rag top
