Author Topic: 68 rs ss am fm multiplex radio  (Read 20404 times)
lilfighta
Re: 68 rs ss am fm multiplex radio
« Reply #15 on: January 21, 2017, 05:54:46 PM »
Paul i had this made but it doesnt sit exactly straight ill try your dimensions
thx mike
fsc66
« Reply #16 on: January 21, 2017, 10:10:15 PM »
Good deal, let me know once done :)
« Reply #17 on: January 21, 2017, 10:54:42 PM »
And try a narrow, taller font.
lilfighta
« Reply #18 on: January 22, 2017, 10:10:27 AM »
yes i made a couple mistakes thank you skinnier and taller letters also letters dont bulge  these are etched into the metal
let see what happens with the next one im trying to get thinner material also the only thing that im confused is that yours is angled more on one side then the next side or this emblem has to look straight going down on both sides about how much lower than the top of door 1" or11/4" 11/2"lower than top of console door and then i can cut the angle i need on both sides to make it look straight going down
thx
fsc66
« Reply #19 on: January 22, 2017, 01:06:11 PM »
The two top and two bottom angles should be the same degrees.
lilfighta
« Reply #20 on: January 22, 2017, 06:28:29 PM »
Hi if you look at your original picture you posted the right side top says tone bottom front- rear look at the angle of the side then look at the left side top says volume bottom balance do you see the difference on the angles  from top to bottom is that the way it has to be does that follow the lines of the console door because console door goes from top to bottom narrower or do they have to be the same angle as the one on the right more angle or the one on left less angle. The top of the label how far is it down from the top of console door it looks to me from other pictures about
thx
fsc66
« Reply #21 on: January 22, 2017, 07:01:04 PM »
It's definitely the way it mounts on the 1966 Impala with multiplex and I would imagine the same with the 68 Camaro. See attached original ad from March 1966 National Geographic. It's a 1966 Caprice but mounts the same as the Impala.
lilfighta
« Reply #23 on: January 22, 2017, 07:14:44 PM »
Yes you are right that is the way it gets mounted im sorry im talking about the sides ts this label suppose to be square or both sides angle in toward the bottom
thx
fsc66
« Reply #24 on: January 22, 2017, 07:23:33 PM »
Yes, trapezoid, larger on top than bottom, it is not a square or rectangle
lilfighta
« Reply #25 on: January 22, 2017, 07:36:37 PM »
oh yea
thx paul
lilfighta
« Reply #26 on: January 26, 2017, 03:54:32 PM »
Hi jason i have a question on the picture you sent it looks like the angle of the right side is more than the left is that a picture angle
or thats how it is the picture is of a reproduction or original
thx
lilfighta
« Reply #27 on: January 28, 2017, 02:19:57 PM »
sorry meant to say Paul was talking to 2 people
fsc66
« Reply #28 on: January 28, 2017, 08:46:11 PM »
Top left and top right same angle
Bottom left and bottom right same angle
Just the picture skewed it a bit
lilfighta
« Reply #29 on: January 29, 2017, 07:00:19 PM »
oh ok
thx
