Author Topic: Exhaust manifold  (Read 4741 times)
Fanthomgreen69
Exhaust manifold
« on: October 25, 2016, 06:06:58 PM »
What kind of manifold is this? Would it be stock? The reason I ask is, I have the same thing. I was going to order a repo set from one of the online companies, but if is correct then I will hold off. The right side looks like it could be for a standard engine with a heater box.
Re: Exhaust manifold
« Reply #1 on: October 25, 2016, 10:02:46 PM »
Looks like a automatic/non-smog small block manifold, but you can pin it further if you can provide the casting number and the date code(s). It is flanged for a heat stove - can't see if it is drilled or maybe a repro non-smog equipped car from this angle. Pretty common -
BTW, what engine combination is this one installed on ?
« Reply #2 on: October 25, 2016, 10:04:53 PM »
I see the rivets still in the holes for securing the heat stove, so likely it's an original. Here again, depends on what engine/trans you are using this on -
Fanthomgreen69
« Reply #3 on: October 26, 2016, 06:49:14 PM »
This was on an EBay ad for a supposed Z/28.
Steve Shauger
    • Vintage Certification
« Reply #4 on: October 26, 2016, 07:57:44 PM »
That is an incorrect manifold for a 69 Z28and non smog. It looks like it's installed on a 69 Z28 based on the valve cover and the single 3/8 fuel line pictured.
Steve Shauger
